Are there any other ways of parametizing S?
  • Thread starter Sneaksuit
In summary, If we want to parametrize S, where S is part of the plane z = y - 2 that lies inside the elliptic cylinder x^2 + 4y^2 = 4, we can use the following parametric equations: x = 2sin(t), y = cos(t), z = cos(t) - 2. However, it is also possible to parametrize S by switching the sine and cosine in these equations and adding an arbitrary phase shift. Another way to parametrize S is using Klein's equation, which would parametrize the entire surface instead of just the curve of intersection. There is no specific starting point or direction for the parametrization.
Sneaksuit
If S is part of the plane [tex] z = y - 2 [/tex] that lies inside the elliptic cylinder [tex]x^2 + 4y^2 = 4[/tex] and I want to parametrize S I will let
[tex]x = 2sin(t)[/tex]
[tex]y = cos(t)[/tex]
[tex]z = cos(t) - 2[/tex]
I assume this is right but let me know if not. My question is are there any other ways of parametizing S?
I think you ahve your cosins and sins switched. Which direction does your parameter go? I am assuming counter clockwise.
Come to think of it keeping them that way will also work, provided that you aren't going for a specific parametric starting and ending point.
There is no specific starting point. Do you know of another way parametrizing S though?
Basically as he said, make every cosine a sine and the sine a cosine. I suppose you could also add an arbitrary phase shift to the trig functions as well (the sine-cosine reversal is a special case of that).
So just switch my sin and cosin and that is another way of parametrizing S?
I don't really understand your solution, since apparently you're parametrizing a surface (so you need 2 parameters). I suppose the solution is simply :
[tex] x=Rcos(t)\quad y=\frac{R}{2}sin(t)\quad z=\frac{R}{2}sin(t)-2\quad R\in[0;2]\quad t\in[0;2\pi][/tex]
Yes. It will draw the same curve but from a different starting point and direction.
Those parameters would draw the curve of intersection. Parametrizing the entire surface, you would use klein's equation
FAQ: Are there any other ways of parametizing S?
What is parametizing S?
Parametizing S refers to the process of assigning or defining parameters to a given set S. Parameters are variables that can be used to describe or measure the characteristics or behavior of a system or phenomenon.
Why is it important to parametize S?
Parametizing S is important because it allows us to gain a better understanding and control of the system or phenomenon. By assigning parameters, we can analyze and manipulate the variables to predict and explain the behavior of S.
Are there any benefits to using alternative ways of parametizing S?
Yes, there are several benefits to using alternative ways of parametizing S. For instance, different parameters can reveal new insights and relationships within the system, leading to more accurate predictions and improved understanding. Additionally, alternative parametization methods can also make complex systems more manageable and easier to study.
What are some common ways of parametizing S?
Some common ways of parametizing S include using mathematical equations, statistical models, and experimental data. Other methods include heuristic or rule-based approaches, machine learning algorithms, and expert systems.
Can parametizing S be applied to any type of system or phenomenon?
Parametizing S can be applied to a wide range of systems and phenomena, including physical, biological, social, and economic systems. However, the specific parameters and methods used may vary depending on the nature of the system and the goals of the study.
