Are there any whole numbers that satisfy this equation?
  • Thread starter Thread starter donglepuss
    Numbers
The equation x^3 - y^2 + ab = a - b(x + y) raises questions about the existence of whole number solutions for x, y, a, and b. Initial discussions reveal that x = y = a = b = 0 is a trivial solution, while other combinations such as x = 1, y = 1, a = -4, and b = 2 were suggested but debated due to the definition of whole numbers. Participants explored various algebraic manipulations and factorizations to find nontrivial positive solutions, emphasizing the need for the variables to be positive integers. The conversation highlighted the importance of defining terms clearly, particularly regarding whether zero is considered a whole number, and concluded with suggestions for specific values of a and b to derive more solutions. Overall, the thread illustrates the complexity of the problem and the collaborative effort to explore potential solutions.
donglepuss
Member warned that some effort must be shown
##x^3-y^2+ab=a-b(x+y)## for any whole numbers ##x,y,a,b##
are there any whole numbers for x,y,a,b, that satisfy x^3-y^2+ab=a-b(x+y)
donglepuss said:
Homework Statement: ##x^3-y^2+ab=a-b(x+y)## for any whole numbers ##x,y,a,b##
Homework Equations: ##x^3-y^2+ab=a-b(x+y)##
Before we can give help, you need to show some effort at getting a solution according to PF guidelines.
Once you do that, do you mean that ##x,y,a,b## actually need to be whole numbers, or is it that they need to be integers instead?
Yes. x=y=a=b=0.
Try turning into a quadratic or cubic by selecting the right variable.
##x=1,~y=1,~a=-4,~b=2##
Edit: Never mind. I guess whole numbers can't be negative. And apparently it's debatable whether ##0## is a whole number.
Do you have a source that contests this?
The a, b, ab terms suggest factorising how?
Likes DaveC426913
haruspex said:
Perhaps more relevantly, there are nontrivial positive solutions.
Yeah, we're just waiting for the OP to come back with some effort.
I was concerned that the small hint I gave in post #7 might get lost amid the more arcane discussion.😏
Likes DaveC426913
btw, i meant positive integers when i said whole numbers
Likes ryl3gol
Understood. Did you try my hint in post #7?
I don't see an apparent relation, what I could achieve for the moment is :
$$(x+y)(x-y-b)=-x^3+x^2+a-ab$$
by adding and subtracting ##x^2##.
Buzz Bloom said:
Hi Dave:
I found a source that confirms your view.
Well, it wasn't "my" view :wink: - I checked a half dozen sources first, to verify the consensus that 0 is a whole number.
That's not what I have in mind. Think of a and b as the variables of a quadratic.
Yes, I have asked elsewhere and got the same answer. We can find that ##y=\frac{b \pm \sqrt{b^2-4(-x^3-bx-ab+a)}}{2}=\frac{b \pm \sqrt{b^2+4x^3+4bx+4ab-4a}}{2}##
As I posted, think of a and b as the variables, x and y as constants, and factorise on that basis.
(It might be more obvious if you swap the roles of a, b with those of x, y.)
Now we need to see if we can find conditions under which the discriminant is an integer ( necessary but not sufficient). Edit: Maybe we can do the same with other variables and put it together into a tighter condition.
Suggest looking for a simple solution: Set ##a=b=1 ##. I think I found a very simple ##x ## and ##y ##.
As I keep trying to get @archaic to do, it is much easier to find solutions if you flip it around, thinking of a and b as the dependent variables. See posts #7 and #21.
Likes Charles Link
But @archaic is not the OP, who has not shown any effort.
Likes SammyS and Charles Link
Yes, thanks, I should have referenced @donglepuss .
Likes WWGD and Charles Link
We are sort of in limbo=it's an interesting problem, but by PF rules, even if we have a whole set of solutions, we can't post them, but instead are waiting for the OP to see if he can find some solutions...
True, it is frustrating. Happens all too often.
But maybe it is partly because different contributors are pushing in different directions. If you agree my method makes the problem easy, please post so.
do you mean get a as a function of b or the other way around?
Neither.
Get it into the form (a+...)(b+..)=...
  • · Replies 26 ·
  • · Replies 30 ·
