Are there Lewis acids that *don't* have pH's below 7?
  • Thread starter Simfish
  • Tags
    Acids
In summary, when discussing the acidity or basicity of molecules, it is more appropriate to refer to their pKa values rather than their pH values. pH is a property of solutions, while pKa describes the equilibrium between an acid and its conjugate base. There are many acids and bases with pKa values above 7, including common substances such as hydrogen sulfide and ethanol. To measure basicity, one looks at the pKa of the corresponding conjugate acid, with lower pKa values indicating poorer bases.
Simfish
What about Bronsted acids?
And what about Lewis bases that don't have pH's over 7? (same for Bronsted bases)
Chemistry news on Phys.org
First, pH is a property of a solution, namely the concentration of hydrogen ions in that solution. It doesn't really make sense to talk about the pH of a molecule (e.g. what is the pH of acetic acid?) because it depends on a number of factors such as concentration.
When discussion the relative acidity/basicity of molecules, it is useful instead to refer to the pKa of the molecule. This value describes the equilibrium between the acid and its conjugate base and can be used to calculate the pH of a solution containing that molecule.
So, are there acids or bases with pKa values that are above 7? Yes, there are many. For example, some common substances include hydrogen sulfide (pKa = 7.04), hydrogen cyanide (9.21), phenol (9.99), water (15.74), ethanol (15.9), and acetylene (25). You can even start measuring the pKas of protons that almost never are donated to solution like the protons on ethylene (pKa = 44) or ethane (pKa = 51).
For measuring basicity, one just looks at the pKa of the corresponding conjugate acid. Here, the lower the pKa of the conjugate acid, the poorer the base. Some particularly poor bases include the halides (e.g. Cl-, pKa of HCl is -7), acetate (pKa of acetic acid is 4.76), and water (pKa of H3O+ is -1.74).
FAQ: Are there Lewis acids that *don't* have pH's below 7?
What are Lewis acids?
Lewis acids are chemical species that can accept a pair of electrons to form a covalent bond.
How are Lewis acids different from Arrhenius and Bronsted-Lowry acids?
Lewis acids do not necessarily have to produce hydrogen ions (H+) or decrease the pH of a solution to act as an acid, unlike Arrhenius and Bronsted-Lowry acids. Instead, they can form a bond with a base by accepting an electron pair.
Can Lewis acids have a pH below 7?
Yes, some Lewis acids can have a pH below 7 if they are in a solution with a substance that can donate electrons to form a covalent bond.
Are there Lewis acids that have a pH above 7?
Yes, some Lewis acids may have a pH above 7 if they are in a solution with a substance that can donate protons to form a covalent bond.
Can you provide an example of a Lewis acid that does not have a pH below 7?
One example is aluminum chloride (AlCl3), which is considered a Lewis acid because it can accept an electron pair. However, when dissolved in water, it forms hydrochloric acid (HCl), which decreases the pH of the solution. So, in this case, the pure Lewis acid itself does not have a pH below 7, but its reaction with water does.
