- #36
zonde
- 224
Why exactly I should look up definition of the stress-energy tensor? We are talking about pressure (that's kinetic theory) and degenerate matter (that's QM). We are not talking about GR.Ken G said:Pressure is a diagonal stress-energy tensor. If you look up the definition of the stress-energy tensor, you will see no reference to any collisions anywhere.
And GR is not replacement of either theory. Therefore it does not talk about collisions.
You mean that kinetic theory is a myth?Ken G said:That's another widespread myth about pressure.
Why are you bringing into discussion all this "pressure gradient", "momentum flux", "momentum deposition", "momentum flux gradient".Ken G said:The main thing to get is that pressure gradients produce forces on fluids, which simply means, gradients in momentum fluxes generate momentum deposition when you average over the fluid. The momentum deposition has nothing to do with collisions, it is just how momentum flux gradients work, they yield momentum piling up in a volume. The thing you need collisions for is to keep the fluid behaving nicely, like with locally isotropic distribution functions and so forth (so the stress-energy tensor stays diagonal and pressure takes on its simple meaning). You don't even need collisions off a boundary, the force produced by pressure is perfectly capable of acting on the fluid itself and not anything else.
And what the hell do you mean by that "the stress-energy tensor stays diagonal and pressure takes on its simple meaning"? Stress-energy tensor does not describe pressure. Pressure is parameter in stress-energy tensor. You put it into get stress-energy tensor.
You have energy eigenstate for a particle in a potential well. A wall does not create potential well.Ken G said:Indeed, I think you raise an interesting point, that something quite strange must occur when a degenerate gas encounters a wall. The problem is that you can no longer treat them as being in momentum eigenstates if you have a wall, so the energy eigenstates are not momentum eigenstates any more and life gets a bit complicated, but I presume they induce the normal pressure that an ideal gas would at the same energy density.
