Are water waves indicative of QED?
In summary, The conversation discusses the idea of creating ripple waves on a calm body of water through controlled wind, and questions if this is indicative of quantum mechanics at work. The participants also discuss the role of QED and probabilistic clustering in understanding these waves. However, there is still uncertainty and disagreement on the exact mechanisms behind this phenomenon.
truhaht
Maybe not.
I'm just thinking, idly...
If, under controlled conditions, you blow a steady gentle breeze across the surface of an otherwise perfectly calm body of water, I figure you'd make a ripple of (regular) waves. A steady-state analog input, yet quantized rhythmic output. Do you suppose that is somehow indicative of quantum mechanics at work? ..perhaps a reflection of the fine structure of matter and Planck's constant?
I just find it interesting; thanks
I have thought this before and came to the conclusion that it must be. The reason we see waves is due to the way in which the water is chemically bonded, which is in turn due to QED. I mean why is it we don't see a square wave or saw wave or some sort of random wave. I don't know for sure but I think it is.
Instinctively, it's no mystery that when chaos is forced into an orderly march, the transition would have to be a choppy one. [To wit, The perfectly calm body of water is a chaos of individually buzzing/moving molecules and the breeze exerts a force that tends those nearest the surface to move in conform.]
Maybe most of QED is fairly instinctive.
Probabilistic clustering is another example I can come up with that is instinctively-grasped. QED is an expression of probabilities, of course.
This sounds pretty, but isn't very meaningful.
truhaht said:
Maybe not.
What do you mean by "quantized" here? It's certainly not the same meaning as in QM.
for indulging me.
I appreciate your curiosity and interest in making connections between different phenomena. However, I do not believe that water waves are indicative of quantum mechanics or QED (quantum electrodynamics). While both water waves and quantum mechanics involve the concept of waves, their underlying principles and mechanisms are vastly different.
Water waves are a result of the interaction between wind and the surface tension of water. They follow classical physics principles and can be explained using fluid dynamics. On the other hand, quantum mechanics is a fundamental theory that describes the behavior of particles at the atomic and subatomic level. It involves complex mathematical equations and principles such as superposition and uncertainty, which are not applicable to water waves.
Furthermore, QED specifically deals with the interactions between particles and electromagnetic fields, while water waves do not involve any electromagnetic forces. Therefore, I do not believe that water waves can be considered as an indication of QED in any way.
However, your observation and curiosity are commendable, and I encourage you to continue exploring and making connections between different scientific concepts. Who knows, you may stumble upon a new and exciting discovery in the process.
FAQ: Are water waves indicative of QED?
What is QED?
QED stands for Quantum Electrodynamics, which is a theory that describes the behavior of electromagnetic forces and interactions at the quantum level. It is a fundamental part of the Standard Model of particle physics.
How are water waves related to QED?
Water waves are not directly related to QED. QED is a theory that explains the behavior of electromagnetic forces, while water waves are a result of the interaction between water molecules and external forces such as wind or gravity.
Are water waves a form of electromagnetic radiation?
No, water waves are not a form of electromagnetic radiation. Electromagnetic radiation refers to waves of electric and magnetic fields that travel through space. Water waves, on the other hand, involve the physical displacement of water molecules.
Can QED explain the behavior of all types of waves?
No, QED only applies to electromagnetic waves. There are other theories, such as quantum mechanics and general relativity, that explain the behavior of other types of waves such as matter waves or gravitational waves.
How does QED impact our understanding of water waves?
QED does not have a direct impact on our understanding of water waves. However, studying the behavior of waves in different systems, such as water waves and electromagnetic waves, can help us gain a better understanding of the fundamental principles of physics.
