Are x-rays from lightnings and magnetism the same effect?
In summary: They then emit x-rays as the electrons return to their ground states.This is not to say that the generation is not, as with your cell phone antennas, still a matter of moving charges generating em radiation. It's just that the process is atomic instead of merely within the Fermi sea of electrons swimming in the conducting region of a metal.Electromagnetic acceleration of free electrons (which includes e.g. bremsstahlung).Electromagnetic acceleration of non-electron charged particles.Likely we can discount acceleration of say protons or nitrogen ions as well as nuclear transitions which are up in the gamma ray spectrum. (Interesting
consuli
62
Hello!
In 2010 Richard A. Lovett has published a photo from a ligthning-strike in the national geographic magazine, which shows significant x-ray radiation.
Obviously a lightning-strike is an electrical current in air (and water).In electrodynamics an electrical current in metals generates magnetic fields and (photon based) radio signals.
My questions:
  1. Are x-rays from lightnings and magnetism/ radio signals basically caused by the same quantum electrodynamics effect related to electrons?
  2. Is the type of photon-wave generated only dependend from the medium, in which the current flows?
Consuli
You're not going to get high frequency electromagnetic radiation like x-rays or even visible light from currents in metals. The x-rays from lightning and from x-ray machines comes from individual atomic excitations. I think lightning simply heats the air hot enough to incandesce with significant x-rays. This isn't surprising given its hotter than the surface of the sun which is itself hot enough to radiate some in the x-ray band.
X-ray tubes aim an electron beam into a copper or tungsten target and the high energy electrons knock other electrons in the metalic atoms to high excitation. They then emit x-rays as the electrons return to their ground states.
Likes Nik_2213 and davenn
If this would be true, the x-ray from a lightning would not be synchronous with the electrical discharge in a lightning-strike, as latest lightning experiments show.
phys.org said:
The results show that most of the X-rays are synchronous with the initiating negative flow of charge within the cloud, as the moving electrons create X-rays via bremsstrahlung in bursts immediately preceding a current pulse of the lightning strike.
( Source: https://phys.org/news/2015-09-x-rays-lightning-aircraft-in-flight.html )
Consuli
It sound like your reference is better read than I on the subject. [Could you link the actual posting, your quote links to a blank]. But there's only so many fundamental ways to produce x-rays.
  • bound state to bound state electron transitions in an atom (by whatever excitation mode produced the vacancy).
  • free state to bound state electron transitions in an atom.
  • Electromagnetic acceleration of free electrons (which includes e.g. bremsstahlung).
  • Electromagnetic acceleration of non-electron charged particles.
Likely we can discount acceleration of say protons or nitrogen ions as well as nuclear transitions which are up in the gamma ray spectrum. (Interesting papers on gamma rays from lightning strikes when I did a quick search). I would re-classify the others along causal lines:
  • Electronic excitation from molecular collisions (gaseous incandescence),
  • Electronic excitation from impinging free electrons (electroluminescence, and plasma incandescence),
  • Electron scattering (bremsstahlung, etc were the high energy electron is the source)
I would discount the first of these latter three cases. Naturally at x-ray energies we have ionization and plasma instead of gas. My intimation was plasma incandescence but you're reference seems to imply scattering effects, i.e. bremsstrahlung.
Beyond that... my final answer to your queries to the best of my knowledge is:
1.) yes it's all always the same quantum electrodynamics. (bound transitions demonstrate more of the quantum aspect)
and
2.) The only dependency with respect to the medium is going to be some spectral dependency from that radiation resulting in bound electron transitions but less so when dealing from ionized atoms reabsorbing free electrons. And, I think, very little dependency on the type of medium beyond density when it comes to bremsstahlung.
Likes davenn and anorlunda
Yes, agreed, this article, one of the OP's links ...
https://news.nationalgeographic.com/news/2010/12/101223-lightning-x-rays-camera-science-technology/
... speaks of the x-rays being generated by the lighting strike on the metal tower and no comments about anything being generated with interaction with atmospheric atoms present along the strike path
UNFORTUNATELY, they didn't show one of their x-ray images
The lightning strike on the metal tower is much the same as this process you stated, and I can see how that fits...
A "beam/stream" of very high energy electrons striking metal
Consuli ... that statement needs correcting, just so you understand correctly
A DC electrical current can generate a magnetic field ... but NOT an EM emission aka radio waves ( Electromagnetic)
An AC electrical current can generate both a magnetic field and an EM emission
not sure how you come to that conclusion ??
X-rays and radio signals are both EM emission
magnetism is not
not a well structured question
The type of EM (photons) generated is related to the energy levels injected into the system
As @jambaugh said earlier...
HI energy excitation is required
What does that effectively mean, then?
A lightning strike is a DC discharge. Does it mean, it cannot generate an EM wave emission [just a single (x-ray) impuls]?
Consuli
it's a lot more complex than a plain DC voltage as seen from battery or an AC to DC power supply
The majority of the lightning discharge is in a single direction but once the channel has been formed, there can be
a number of oscillations back and forward
But even the initial pulse of the lightning strike produces a large pulse of EM …. this can be heard on any am broadcast radio receiver.
The same thing happens when you close the switch on a DC or AC power supply
Have you ever wondered why a light turns on the moment you flick the switch ? There is an initial pulse of EM energy that goes around the circuit
Electrons don't travel fast enough to produce the near instantaneous effect that is observed
The X-rays are produced by a different method, that was explained in an earlier post by jambaugh
Dave
And this isn't a contradiction to
If not, could you go further into detail, why this isn't a contradiction?
Consuli
no it isn't a contradiction
it's the same thing …. as I said earlier ... a beam/stream of high energy electrons striking a metal target
as Jambaugh stated in a previous post of his
maybe you missed his other comment ??
  • Electromagnetic acceleration of free electrons (which includes e.g. bremsstrahlung).
Lightning appears to have 2 known ways it produces x-rays
1) bound state to bound state electron transitions in an atom (by whatever excitation mode produced
the vacancy).
when it hits a metal target … a plane or something on the ground, as in that metal tower the rockets launched from in one of your links
2) Electromagnetic acceleration of free electrons (which includes e.g. bremsstrahlung).
which is occurring within the clouds
Related to Are x-rays from lightnings and magnetism the same effect?
1. Are x-rays produced during lightning strikes?
Yes, x-rays are produced during lightning strikes. When lightning strikes, it creates a powerful electrical current that heats up the surrounding air to extremely high temperatures. This rapid heating and cooling of the air molecules produces x-rays.
2. How are x-rays from lightning different from x-rays produced by medical equipment?
The main difference is the energy and intensity of the x-rays. X-rays produced by medical equipment are highly controlled and typically have lower energy levels. X-rays from lightning, on the other hand, are much more powerful and have higher energy levels. This is due to the extreme conditions of the lightning strike.
3. Can we detect x-rays from lightning strikes?
Yes, x-rays from lightning strikes can be detected using specialized equipment such as x-ray detectors or gamma ray detectors. These detectors are able to measure the energy and intensity of the x-rays produced during a lightning strike.
4. Are x-rays from lightning strikes harmful to humans?
Yes, x-rays from lightning strikes can be harmful to humans. Exposure to high levels of x-rays can cause damage to cells and tissues in the body. However, the risk of being exposed to x-rays from a lightning strike is very low as the x-rays dissipate quickly and are only produced for a short period of time during the strike.
5. Can x-rays from lightning strikes be used for any practical purposes?
Yes, x-rays from lightning strikes can be used for practical purposes such as studying the effects of lightning on the atmosphere and for understanding the physics of lightning. They can also be used to study the properties of materials that are struck by lightning, such as trees or buildings, and to improve lightning protection systems.
  • Electromagnetism
  • Quantum Physics
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
