MHB Are you smarter than a Singaporean 10 year old?
  • Thread starter Thread starter GLONE007
    Year
The discussion revolves around a math problem from The Guardian that challenges readers to determine the length of remaining string after specific cuts. The problem states that Mary cut off 2/5 of a string and later removed another 14 meters, with the remaining string's length to the total cut off being in a ratio of 1:3. A step-by-step breakdown of the solution is provided, leading to the conclusion that the original length of the string is 40 meters, resulting in 10 meters remaining after the cuts. Participants express confusion and seek clarification on the solution process, emphasizing a desire for a clearer understanding. The thread illustrates the challenge of grasping mathematical concepts presented in a problem-solving context.
GLONE007
So i was looking through The Guardian(newspaper) and found this question, Titled 'are you smarter then a 10 year old?' and as you can guess i had no clue what to do. Also i thought if i looked at the answer maybe i would realize how it worked. Oh. how wrong was I! Is anyone able to break it down even more?. so that someone like 'me' can understand how it is done and how it works.
1. Mary cut off 2/5 of a piece of string. Later, she cut off another 14 m. The ratio of the length of string remaining to the total length cut off is 1 : 3. What is the length of the remaining string?
A. 5 m
B. 7 m
C. 10 m
D. 14 m
Solution is C.
I saw two ways of doing this yet they both through me off, i was wondering if someone could. in a sense talk it through step by step.As i am determined to understand how it works.
Many thanks.
Mathematics news on Phys.org
Re: Are you smarter then a Singaporean 10 year old?
what we wind up with is (where $\ell$ is the original length in m):
$$0.6\ell-14=\frac{1}{3}\left(0.4\ell+14\right)$$
$$1.8\ell-42=0.4\ell+14$$
$$1.4\ell=56$$
$$\ell=40$$
Hence:
$$\frac{3}{5}40-14=24-14=10$$
edit: I've moved this thread here, as it's a better fit.
I believe I can explain it well, because tbh is quite easy to understand if you check out my way. The simplest thing you could've done is to express the total length of the string. You can use any letter you want, but usually l stands for length in Maths as Mark has used.
\ell=
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
