MHB Area and angles of iso triangle given find sides
The discussion focuses on calculating the sides of an isosceles triangle with an area of 100 and internal angles of 40°, 70°, and 70°. The area formula A = 1/2 * b * h is applied, leading to the equation 100 = 1/2 * (z * sin(70°)) * (2z * cos(70°)), where z represents the length of one of the equal sides. The Law of Sines is also referenced to derive additional relationships, specifically A = B * (sin(a) / sin(b)) and A_T = 1/2 * B^2 * sin(a). Simplification techniques, such as using the identity sin(2x) = 2cos(x)sin(x), are suggested for further calculations. The thread also includes a user inquiry about posting new threads on the forum.
karush
MHB
Given an Isosceles triangle with the area of 100 with internal angles of
$$40^o, 70^o,70^o$$
$A=\frac{1}{2}bh$
so
$100=\frac{1}{2}\left(z\sin\left({70^O}\right)\right)\left(2z\cos\left({70^o}\right)\right)$
$z$ is length of one the equal sides
At least started here
Mathematics news on Phys.org
Consider the following diagram:
Now, using the Law of Sines, we may state:
$$A=B\frac{\sin(a)}{\sin(b)}$$
If we denote the area of the triangle with $A_T$, then we may also state:
$$A_T=\frac{1}{2}B^2\sin(a)$$
Now, just solve for $B$, and then you will know $A$ as well. Then you will have formulas that you can plug into the given data. :)
$$40^o, 70^o,70^o$$
$A=\frac{1}{2}bh$
so
I think what you have done is correct just remember that $\sin(2x) = 2\cos(x)\sin(x)$ to simplify.
MarkFL said:
Hello, Admin. How do I post a thread? No bottom to click. I can only reply. (Worried)
stud17 said:
...Hello, Admin. How do I post a thread? No bottom to click. I can only reply. (Worried)
If you browse to a forum, you will see, above and below the thread listing, large buttons labeled "+ Post New Thread" that will allow you to begin a new thread in that forum. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
