myanmar
- 33
Last few I can't seem to do, but on the others, can someone check my answers?. The last few I need help getting through.
1. Find the volume of the solid formed when the region bounded by the curves y = x^3 + 1, x = 1 and y = 0 is rotated about the x-axis.
My answer: int(pi(x^3+1)^2,x,-1,1)
2. Find the volume of the solid of revolution obtained by revolving the region bounded by y = 1/x and the lines x = pi/8 and x = pi/2 around the x-axis the x-axis.
My answer: int(pi(1/x)^2,x,pi/2,pi/8)
3. Find the area bounded by the curves f(x) = x^3 + x^2 and g(x) = 2x^2 + 2x.
int((x^3+1)-(2x^2+2x),x,-1,0) + int((2x^2+2x)-(x^3+1),x,0,2)
4. Find the area bounded by the curves y = sqrt(x), y = (5-x)/4, and y = (3x-8)/2
int(sqrt(x)-(5x-4)/4,x,1,3) + int(sqrt(x) - (3x-8)/2,x,3,4)
5. Let R be the region bounded by: y = x^3, the tangent to y = x^3 at (1,1), and the x-axis. Find the area of R integrating: a) with respect to x, and b) with respect to y.
Solving for tangent yields tangent = 3x-2
integrating for x yields
int(x^3-(3x-2),x,0,1)
b) Help me with this, not sure how to do at all.
6. Find the volume of the solid generated by revolving the region bounded by the graphs of y = x^2 - 4x + 5 and y = 5 - x about the line y = -1.
disk: int(pi((5-x)^2-(x^2-4x+5)^2),x,0,2)
shell: int(2pix(-x^2+3x),0,3)
7. Use cylindrical shells to find the volume of the solid obtained by revolving around the y-axis the region bounded by the curves y^2 = 8x and x = 2.
int(2pix(2sqrt(2x),x,0,2)
8. A cylindrical hole is drilled through the center of a sphere of radius R. Use the method of cylindrical shells to find the volume of the remaining solid, given that the solid is 6 cm high.
I believe the answer is 36 pi in^3, but can not seem to do this problem with the shell method.
9. Find the volume of the solid generated by revolving about the line x = -1, the region bounded by the curves y = -x^2 + 4x - 3 and y = 0.
10. Consider the region in the xy-plane between x = 0 and x=pi/2 bounded by y = 0 and y = sin x. Find the volume of the solid generated by revolving this region about the x-axis.
11. Let R be the region bounded by y = 1/x, y = x^2, x = 0, and y = 2. Suppose R is revolved around the x-axis. Set up but do not evaluate the integrals for the volume of rotation using: a) the method of cylindrical shells; b) the method of circular disks.
