Area element, volume element and matrix
In summary: Suppose you have a surface parametrized as a function of (x, y, z) coordinates, and you want to solve for the volume or area. If you use the equation from the wiki article, you get an equation in the form dA = (1/2)dx dy. However, this equation is not always solvable. There are several methods that can be used to solve this equation, but they all have their own drawbacks. One method is to try to find the inverse of the matrix A, but this can be difficult to do. Another method is to use a variation of the Euler's equation, which is a more general equation that can be solved for more types of problems. In summary,
Jhenrique
685
I found this matrix in the wiki:
https://fr.wikipedia.org/wiki/Vites...luation_en_coordonn.C3.A9es_cart.C3.A9siennes
I think that it is very interesting because it express d²A not trivially as dxdy. So, I'd like of know if exist a matrix formulation for volume element and area element in others coordinate system...
[tex]\vec{x}=\vec{x}(u,v).[/tex]
Then the surface-element normal vectors are given by
[tex]\mathrm{d}^2 \vec{F}=\frac{\partial \vec{x}}{\partial u} \times \frac{\partial \vec{x}}{\partial v} \mathrm{d} u \mathrm{d} v.[/tex]
This is clear from the geometric meaning of the vector product as a (axial) vector with magnitude of the area of the parallelogram spanned by the two vectors and directed perpendicular to the surface with the orientation given by the right-hand rule.
In the same way, from the triple product giving the volume of a parallelipiped spanned by three vectors
[tex]\mathrm{d}^3 \vec{x}=\mathrm{d} u \mathrm{d} v \mathrm{d} w \left (\frac{\partial \vec{x}}{\partial u} \times \frac{\partial \vec{x}}{\partial v} \right ) \cdot \frac{\partial \vec{x}}{\partial w},[/tex]
where [itex](u,v,w)[/itex] are arbitrary "generalized coordinates". This is of course identical with the Jacobian determinant of the transformation law from generalized to Cartesian coordinates,
[tex]\mathrm{d}^3 \vec{x} =\mathrm{d} u \mathrm{d} v \mathrm{d} w \det \left (\frac{\partial(x,y,z)}{\partial(u,v,w)} \right ).[/tex]
Actually, the formula shows a determinant.
The formula gives dA, not d2A. The reason it is not shown as dxdy is that the area is for a region that is approximately a sector of a circle, rather than for a rectangular area element. In the drawing in the wiki article, the coordinates of point M' are (x + dx, y + dy) and the coordinates of M are (x, y). If you connect point M with a segment perpendicular to OM', you get something that is nearly a right triangle. The area of this triangle would be approximately (1/2)dx dy, so it's clear that the area of the sector can't be dx dy.
Related to Area element, volume element and matrix
1. What is an area element?
An area element is a small piece or section of a surface that is used to measure the total area of the surface. It is typically represented by the symbol dA and is used in various mathematical and scientific calculations.
2. What is a volume element?
A volume element is a small unit or section of space that is used to measure the total volume of a three-dimensional object or region. It is typically represented by the symbol dV and is used in various mathematical and scientific calculations.
3. How are area and volume elements related?
Area and volume elements are related in that they both represent small units of measurement for two- and three-dimensional quantities, respectively. They are used to calculate the total area or volume of a larger object or region by integrating over the entire surface or space.
4. What is a matrix?
A matrix is a rectangular array of numbers or symbols arranged in rows and columns. It is used to represent and manipulate mathematical and scientific data, equations, and transformations.
5. How are matrices used in scientific research?
Matrices are used in scientific research for a variety of purposes, including solving systems of equations, performing statistical analyses, and representing complex data sets. They are also commonly used in the fields of physics, engineering, and computer science for modeling and simulations.
  • Math Proof Training and Practice
  • Linear and Abstract Algebra
