MHB Area Inside Circle x^2+y^2=a^2 Above b=7
  • Thread starter Thread starter wonguyen1995
    Area Circle
The discussion focuses on finding the area inside the circle defined by the equation x^2+y^2=a^2, specifically above the line y=b, where -a ≤ b ≤ a. There is a suggestion that the original question may contain a typo regarding the line's position. Participants clarify that the area can be computed either through integration or geometrically. The geometric method is highlighted as simpler, referencing the area of a triangle formula. The conversation emphasizes the need for clarity in the problem statement to proceed effectively.
wonguyen1995
Find area inside circle x^2+y^2=a^2, above 7=b, -a \le b \le a ?? i think f of y right?
(-a to a) minus (-a to b)?
Maybe it's a typo and should read "above $y=b$". That is, find the area inside the circle $x^2+y^2=a^2$ that is located above the line $y=b$, where $-a\le b\le a$.
Sorry, I don't understand your remark.
That is it, i mistake.
so can you help me??
Do you need a solution that uses integral? It's easier to find the area geometrically as described in Wikipedia using the fact that the area of a triangle with sides $u$ and $v$ and angle $\varphi$ between them is $\frac{1}{2}uv\sin\varphi$.
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 29 ·
