Area of loops and arcs of prolate cycloids
In summary, the conversation discusses the lack of information regarding the equations for calculating the area and line lengths of loops and arcs of prolate cycloids. While standard cycloids are well-documented, there is a scarcity of resources for looping cycloid curves. One suggestion is to consider the fact that the circle does not slip and therefore one complete cycle must trace out a circumference of the same length. However, this does not apply to prolate cycloids as they do slip and create loops.
liometopum
127
24
Does anyone know of solutions (or sources showing them) to the area and line lengths of the loops and arcs of prolate cycloids? Standard cycloids are well discussed online, but equations relating to looping cycloid curves appear absent. I have not seen an equation relating to either loop area or arc area, for example.
couldn't you compute this by noting that the circle doesn't slip so one complete cycle must trace out a circumference of the same length to match it for starters?
The circle does slip in the case of prolate cycloids, creating the loops. And it 'skids' for curtate cycloids.
Related to Area of loops and arcs of prolate cycloids
1. What is a prolate cycloid?
A prolate cycloid is a curve that is traced by a point on the circumference of a circle as it rolls along a straight line in the same plane. It is similar to a cycloid, but with a longer horizontal line and a shorter vertical line.
2. How is the area of a loop or arc of a prolate cycloid calculated?
The area of a loop or arc of a prolate cycloid can be calculated using the formula A = 2πa², where a is the radius of the generating circle.
3. What is the difference between a loop and an arc of a prolate cycloid?
A loop of a prolate cycloid is a complete rotation of the generating circle, while an arc is a portion of the curve that is less than a full rotation.
4. Can the area of a loop or arc of a prolate cycloid be found using integration?
Yes, the area can also be calculated using integration. The integral for the area of a prolate cycloid is given by ∫ 2πa√(1 + (dy/dx)²) dx, where a is the radius of the generating circle and dy/dx is the derivative of the cycloid equation.
5. What real-world applications use prolate cycloids?
Prolate cycloids have various applications in engineering and physics, such as in the design of gears and camshafts, as well as in the study of rolling objects and projectile motion. They are also used in the creation of mathematical curves and animations.
  • Classical Physics
  • Beyond the Standard Models
