Area of Region II: 16 & 256/3 sq. units
  • MHB
  • Thread starter paulmdrdo1
  • Tags
    Area
In summary, the conversation was about finding the area bounded by two different curves. The first curve was defined by the equations $y^2=4x$ and $y=2x-4$, and the second curve was defined by $y=x+3$ and $y=x^2+x-13$. The points of intersection for the first curve were found to be at $x=4,-2$ and the points of intersection for the second curve were at $x=4,-4$. The correct integral was calculated for the second curve, but the first curve was incorrect due to a mistake in finding the points of intersection. The concept of using even and odd functions to simplify integrals was also mentioned in the conversation.
paulmdrdo1
385
again i just want to check if my answers were correct. i didn't include the complete solution because I'm in a hurry our finals is just around the corner. if my answers are not correct just say so and i will try to solve it again until i get it. thanks!
1. find the area bounded by $y^2=4x$ & $y=2x-4$.
points of intersection are x=4,-2
$\displaystyle\int_{-2}^4 (\frac{1}{2}x+2-\frac{1}{4}x^2)dx$ = $\left[\frac{x^2}{4}+2x-\frac{x^3}{12}\right]_{-2}^4$
it turns out that the area is 16 sq. units
2. find the area bounded by $y=x+3$ and $y=x^2+x-13$
points of intersection are x=4,-4
$\displaystyle\int_{-4}^4 (16-x^2)dx = \left[16x-\frac{x^3}{3}\right]_{-4}^4$
the area is 256/3 sq. units.
Hello,
I have not check your answer but could you solve 2 in another way( a way that make it more easy to put in the value after you integrate) You should be able to do this.
Tips:
Look what MarkFL comment on your early topic
i don't know how to do that. but markfl said in my other topic that i should use even-function rule which i have no idea about.
There are a couple of theorems about symmetries of functions and integrals on symmetric regions. If $f$ is an even function (that is, $f(x)=f(-x)$ for all $x$), and suitably well-behaved (continuous is sufficient, but not necessary) then
$$\int_{-a}^{a} f(x) \, dx=2 \int_{0}^{a}f(x) \, dx.$$
If $f$ is an odd function (that is, $f(x)=-f(-x)$ for all $x$), and suitably well-behaved, then
$$ \int_{-a}^{a}f(x) \, dx=0.$$
are my answers above correct?
2 is correct; you could have used the even function trick that Petrus, MarkFL, and I have mentioned to simplify your calculations, but your result is fine.
1 is incorrect. $x=-2$ is not in the domain of $y^{2}=4x$. If you plug in $x=-2$ on the RHS, you get a negative number, whereas the LHS must always be non-negative. I would consider tilting your head on its side, and do a $y$-integral on this one, so that you don't have to break your integral up into two regions.
Start by plotting the region, and see if that gives you an idea.
The points of intersection are where the two functions are equal. We can see from the second that [tex]\displaystyle \begin{align*} y = 2x - 4 \implies 2y = 4x - 8 \implies 4x = 2y + 8 \end{align*}[/tex], and so substituting into the first equation we get
[tex]\displaystyle \begin{align*} y^2 &= 2y + 8 \\ y^2 - 2y - 8 &= 0 \\ ( y - 4 ) ( y + 2) &= 0 \\ y = 4 \textrm{ or } y &= -2 \end{align*}[/tex]
From here we can see that the two points of intersection are [tex]\displaystyle \begin{align*} (x, y) = (4, 4) \end{align*}[/tex] and [tex]\displaystyle \begin{align*} (x , y ) = ( 1, -2) \end{align*}[/tex].
Now, if we draw out the region, it would be easiest to evaluate the area of if we dealt with horizontal strips. Each horizontal strip is bounded on the left by the function [tex]\displaystyle \begin{align*} x = \frac{1}{4}y^2 \end{align*}[/tex] and bounded on the right by the function [tex]\displaystyle \begin{align*} x = \frac{1}{2}y + 2 \end{align*}[/tex]. We would then sum these strips between [tex]\displaystyle \begin{align*} y = -2 \end{align*}[/tex] and [tex]\displaystyle \begin{align*} y = 4 \end{align*}[/tex]. So the area can be evaluated as
[tex]\displaystyle \begin{align*} A &= \int_{-2}^4{\int_{\frac{1}{4}y^2}^{\frac{1}{2}y + 2}{1\,dx}\,dy} \\ &= \int_{-2}^4{\left[ x \right]_{\frac{1}{4}y^2}^{\frac{1}{2}y + 2}\,dy} \\ &= \int_{-2}^4{ \frac{1}{2}y + 2 - \frac{1}{4}y^2\,dy } \\ &= \left[ \frac{1}{4}y^2 + 2y - \frac{1}{12}y^3 \right] _{-2}^4 \\ &= \left[ \frac{1}{4}(4)^2 + 2(4) - \frac{1}{12}(4)^3 \right] - \left[ \frac{1}{4}(-2)^2 + 2(-2) - \frac{1}{12}(-2)^3 \right] \\ &= \left[ 4 + 8 - \frac{16}{3} \right] - \left[ 1 - 4 + \frac{2}{3} \right] \\ &= 12 - \frac{16}{3} + 3 - \frac{2}{3} \\ &= 15 - \frac{18}{3} \\ &= 15 - 6 \\ &= 9 \end{align*}[/tex]
So the area is [tex]\displaystyle \begin{align*} 9\,\textrm{units}^2 \end{align*}[/tex].
i assume you switched the variables in 1, but you've done the arithmetic incorrectly. try solving it again and you'll get 9 sq. units.
why did you multiply the 1st equation by 2? and how can we determine that this technique is valid to a problem?
$\displaystyle \displaystyle \begin{align*} y = 2x - 4 \implies 2y = 4x - 8 \implies 4x = 2y + 8 \end{align*}$
You were given $y^2=4x$, and so multiplying the other equation by $2$ allows $4x$ to be expressed as a function of $y$. If we have two quantities that are equal, can we not multiply both sides by the same value and still have equality?
FAQ: Area of Region II: 16 & 256/3 sq. units
What is the formula for finding the area of Region II?
The formula for finding the area of Region II is A = 16 + 256/3, where A represents the total area in square units. This formula can also be expressed as A = 256/3 + 16 or A = 256/3 + 48/3.
How do you interpret the fraction 256/3 in the area formula?
The fraction 256/3 represents the area of the triangle in Region II, which is half of the total area. This fraction can also be written as 85 1/3, meaning that the triangle has an area of 85 1/3 square units.
How is Region II different from Region I in terms of area?
Region II is a combination of a rectangle with an area of 16 square units and a triangle with an area of 256/3 square units. Region I, on the other hand, is a rectangle with an area of 16 square units. Therefore, Region II has a larger total area compared to Region I.
Is the area of Region II a whole number or a decimal?
The area of Region II is a decimal, specifically 85 1/3 or 29.6666... square units. This is because the triangle in Region II has a fractional area of 256/3, which cannot be expressed as a whole number.
Can the area of Region II be simplified further?
No, the area of Region II cannot be simplified further. It is already in its simplest form, which is a combination of a whole number and a fraction. Any attempt to simplify it would result in an incorrect value for the total area.
