Area of the event horizon of a rotating black hole
In summary, the Kerr metric describes a black hole with mass M and angular momentum J = aM. The event horizon is located at r+ = M + √(M^2 - a^2). To compute the area of the horizon, one can evaluate the metric for dt = dr = 0 and r = r+, and then integrate over θ and φ.
Afonso Campos
29
The Kerr metric for a black hole of mass ##M## and angular momentum ##J = aM## is
$$ds^{2} = - \frac{\Delta(r)}{\rho^{2}}(dt-a\sin^{2}\theta d\phi)^{2} + \frac{\rho^{2}}{\Delta(r)}dr^{2} + \rho^{2} d\theta^{2} + \frac{1}{\rho^{2}}\sin^{2}\theta (adt - (r^{2}+a^{2}) d\phi)^{2},$$
where ##\Delta(r) = r^{2} + a^{2} - 2Mr##, ##\rho^{2} = r^{2} + a^{2} \cos^{2}\theta## and ##- M < a < M##.
The event horizon is at ##r_{+} = M + \sqrt{M^{2} - a^{2}}##. This is obtained by solving the equation ##\Delta(r) = 0##.How do you use this to compute the area of the horizon?
My idea is to simplify the metric to obtain
$$ds^{2} = - \left( \frac{r^{2} + a^{2} - 2Mr - a^{2} \sin^{2}\theta}{r^{2} + a^{2} \cos^{2}\theta} \right) dt^{2} + \left( \frac{r^{2} + a^{2} \cos^{2}\theta}{r^{2} + a^{2} - 2Mr} \right) dr^{2} - \left( \frac{4aMr \sin^{2}\theta}{r^{2} + a^{2} \cos^{2}\theta} \right) dtd\phi + \left( r^{2} + a^{2} \cos^{2}\theta \right) d\theta^{2} + \sin^{2}\theta \left( \frac{(a^{2} + r^{2})^{2} - a^{2} \sin^{2}\theta (a^{2}-2Mr+r^{2}) }{r^{2} + a^{2} \cos^{2}\theta} \right) d\phi^{2}.$$
Then, I think that the area of the horizon is given by
$$A = \int d\theta\ d\phi\ g_{\phi\phi}g_{\theta\theta}|_{r=r_{+}}.$$
Am I wrong?
You don't need to go through that step. Just evaluate the original metric for the case ##dt = dr = 0## and ##r = r_+##, and integrate over ##\theta## and ##\phi##.
Related to Area of the event horizon of a rotating black hole
What is the area of the event horizon of a rotating black hole?
The area of the event horizon of a rotating black hole is the surface area of the boundary beyond which no light or matter can escape due to the strong gravitational pull of the black hole.
How is the area of the event horizon of a rotating black hole calculated?
The area of the event horizon of a rotating black hole is calculated using the Kerr metric, which is a mathematical model that describes the geometry of a rotating black hole. It takes into account the mass, spin, and charge of the black hole to determine the size of the event horizon.
Can the area of the event horizon of a rotating black hole change?
Yes, the area of the event horizon of a rotating black hole can change over time. As matter and energy fall into the black hole, the event horizon can grow in size. However, the area of the event horizon can never decrease, as this violates the laws of thermodynamics.
Does the rotation of a black hole affect the size of its event horizon?
Yes, the rotation of a black hole does affect the size of its event horizon. A rotating black hole has a larger event horizon compared to a non-rotating black hole with the same mass, due to the centrifugal force caused by its spin.
Why is the area of the event horizon of a rotating black hole important?
The area of the event horizon of a rotating black hole is important because it is a crucial factor in determining the properties and behavior of a black hole. It is also a fundamental quantity in black hole thermodynamics, which helps us understand the relationship between black holes and the laws of physics.
