MHB Area of the parallelogram when diagonal vectors are given.
To find the area of a parallelogram when the diagonals are given, the diagonals can be represented as vectors, specifically $$\alpha = 2i + 6j - k$$ and $$\beta = 6i - 8j + 6k$$. The area can be calculated using the formula $$A = \frac{1}{2} \cdot \| \vec{\alpha} \times \vec{\beta} \|$$. This approach allows for the determination of the area based on the cross product of the diagonal vectors. Understanding the relationship between the diagonals and the sides of the parallelogram is crucial for this calculation. The method effectively provides a means to compute the area without needing the side vectors directly.
Suvadip
I can find the area of the parallelogram when two adjacent side vectors are given. But how to find the area of the parallelogram when diagonals of the parallelogram are given as
$$\alpha = 2i+6j-k$$ and $$\beta= 6i-8j+6k$$
Mathematics news on Phys.org
Hint: If the diagonals of a parallelogram are known then you can find the sides. Figure out how.
Here is a slightly different way to calculate the area of a parallelogram:
According to your question $$\alpha$$ and $$\beta$$ denote the diagonals of a parallelogram. Then the area is
$$A = \frac12 \cdot \| \vec {\alpha} \times \vec {\beta} \|$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
