Area of Triangle with Given Data
In summary, to find the area of the triangle AEF, we can either use the formula A = (1/2)bh, where b is the base and h is the height, or we can use a simpler method by dropping a vertical line from point E to line AD and creating two right triangles, whose areas we can subtract to find the area of triangle AEF. It is not necessary for the triangle to be a right triangle in order to use the area formula.
alextrainer
For b) area of AEF so one side is 7 - don't know how to get other 2 sides
not sure if right triangle; don't think so
how to use the data given since two of sides are slantedView attachment 6374
Mathematics news on Phys.org
A triangle doesn't have to be a right triangle to use the area formula:
\(\displaystyle A=\frac{1}{2}bh\)
For $\triangle AEF$, we have $b=\overline{AF}=7$ and $h=\overline{AB}=5$
Thus, we get:
\(\displaystyle A=\frac{1}{2}\cdot7\cdot5=\frac{35}{2}\)
Suppose you aren't convinced we can use this formula except for right triangles. We could then drop a vertical line from point $E$ to $\overline{AD}$ and label the intersection $G$. $G$ will be to the right of $F$ and we'll say $\overline{FG}=x$
Now, we have the right triangle $AEG$, whose area is:
\(\displaystyle A_1=\frac{1}{2}(5+x)7\)
We also have the right triangle $FEG$ whose area is:
\(\displaystyle A_2=\frac{1}{2}(x)7\)
We can now find the area of $AEF$ by taking $A_1$, the area of the larger right triangle, and subtracting $A_2$, the area of the smaller right triangle:
\(\displaystyle A=A_1-A_2=\frac{1}{2}(5+x)7-\frac{1}{2}(x)7=\frac{1}{2}\cdot7\left((5+x)-x\right)=\frac{1}{2}\cdot7\cdot5=\frac{35}{2}\)
Thanks the line AB equals EF - what threw me off was EF looks at an angle - but I guess I assume since not drawn to scale - the 2 lines are the same.
I would say, going by the diagram, that:
\(\displaystyle \overline{EF}>\overline{AB}\)
But, as I showed, we don't need to know $\overline{EF}$ since $\overline{AB}$ is the altitude of the triangle.
They are not drawn to scale, but it doesn't mean that both are equal. Are you trying to find the area through herons formula? Or it is just that you were unaware about the simpler method?
You don't need to know the lengths of the sides of a triangle to find its area. The area of a triangle is (1/2)*base*height. Here the base is AF which we are told has length 7 and the height is 5.
FAQ: Area of Triangle with Given Data
What is the formula for finding the area of a triangle with given data?
The formula for finding the area of a triangle is A = 1/2 * base * height. This means that you multiply the base and height of the triangle, and then divide that product by 2 to get the area.
What data is needed to calculate the area of a triangle?
You need to know the length of the base and the height of the triangle in order to calculate its area. These two measurements can be in any unit, as long as they are in the same unit (i.e. both in inches or both in centimeters).
Can the Pythagorean Theorem be used to find the area of a triangle?
No, the Pythagorean Theorem can only be used to find the length of one side of a right triangle. It cannot be used to find the area of a triangle.
What is the unit of measurement for the area of a triangle?
The unit of measurement for the area of a triangle is typically square units, such as square inches or square centimeters.
Can the area of a triangle be negative?
No, the area of a triangle cannot be negative. It is a measure of space, and therefore cannot have a negative value.
