Area Triangle: Find Formula in Terms of $p, q, r$
In summary: Substituting this value into the formula for the area, we finally get:$A = \frac{1}{2}\left|\sqrt{p^2-4q}\right|\left|\frac{2r}{p^2-4q}-\frac{p}{2}\right|$In summary, the formula for the area of a triangle whose vertices are the roots of $x^3-px^2+qx-r=0$ in the complex plane is $A = \frac{1}{2}\left|\sqrt{p^2-4q}\right|\left|\frac{2r}{p^
anemone
MHB
POTW Director
3,883
115
Find in terms of $p,\,q$ and $r$, a formula for the area of a triangle whose vertices are the roots of $x^3-px^2+qx-r=0$ in the complex plane.
Mathematics news on Phys.org
The area of a triangle can be calculated using the formula $A = \frac{1}{2}bh$, where $b$ is the base of the triangle and $h$ is the height. In this case, the base of the triangle would be the distance between two of the roots and the height would be the distance from the third root to the line connecting the other two roots.
Let us label the roots as $a, b,$ and $c$. The base of the triangle would be $|a-b|$ and the height would be $|c-\frac{a+b}{2}|$. Therefore, the area of the triangle would be:
$A = \frac{1}{2}|a-b||c-\frac{a+b}{2}|$
Using the quadratic formula, we can express the roots $a$ and $b$ in terms of $p$, $q$, and $r$:
$a = \frac{p+\sqrt{p^2-4q}}{2}$
$b = \frac{p-\sqrt{p^2-4q}}{2}$
Substituting these values into the formula for the area, we get:
$A = \frac{1}{2}\left|\frac{p+\sqrt{p^2-4q}}{2}-\frac{p-\sqrt{p^2-4q}}{2}\right|\left|c-\frac{\frac{p+\sqrt{p^2-4q}}{2}+\frac{p-\sqrt{p^2-4q}}{2}}{2}\right|$
Simplifying this, we get:
$A = \frac{1}{2}\left|\sqrt{p^2-4q}\right|\left|c-\frac{p}{2}\right|$
Now, we need to express the third root $c$ in terms of $p$, $q$, and $r$. From the cubic equation, we can see that:
$c = \frac{r}{a\cdot b}$
Substituting the values for $a$ and $b$ from earlier, we get:
$c = \frac{r}{\left(\frac{p+\sqrt{p^2-4q}}{2}\right)\left(\frac{p-\sqrt{p^2-4q}}{2}\right)}$
Simplifying this,
Related to Area Triangle: Find Formula in Terms of $p, q, r$
1. What is the formula for finding the area of a triangle in terms of $p, q, r$?
The formula for finding the area of a triangle in terms of $p, q, r$ is A = $\sqrt{p(p-a)(p-b)(p-c)}$, where $a$, $b$, and $c$ are the side lengths of the triangle and $p$ is the semi-perimeter, given by $p = \frac{1}{2}(a + b + c)$.
2. How is the formula for finding the area of a triangle derived?
The formula for finding the area of a triangle in terms of $p, q, r$ is derived from Heron's formula, which states that the area of a triangle is equal to the square root of the product of its semi-perimeter and the difference between its semi-perimeter and each side length. By substituting the values of $p$, $a$, $b$, and $c$ into this formula, we arrive at the formula A = $\sqrt{p(p-a)(p-b)(p-c)}$.
3. Can the formula for finding the area of a triangle be used for any type of triangle?
Yes, the formula for finding the area of a triangle in terms of $p, q, r$ can be used for any type of triangle, including equilateral, isosceles, and scalene triangles. As long as the values of $p$, $q$, and $r$ are known, the formula can be used to find the area of the triangle.
4. What is the significance of the values $p$, $q$, and $r$ in the formula for finding the area of a triangle?
The values $p$, $q$, and $r$ represent different aspects of the triangle. $p$ is the semi-perimeter, $q$ is the difference between the semi-perimeter and the longest side length, and $r$ is the difference between the semi-perimeter and the other two side lengths. These values are used to calculate the area of the triangle in terms of its side lengths.
5. Are there any other formulas for finding the area of a triangle?
Yes, there are other formulas for finding the area of a triangle, such as the base-height formula (A = $\frac{1}{2}bh$) and the trigonometric formula (A = $\frac{1}{2}ab\sin{C}$). However, the formula in terms of $p$, $q$, and $r$ is useful for finding the area of a triangle when the side lengths are not known, but the semi-perimeter and the difference between the semi-perimeter and each side length are known.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
