Area Under Curve: Calculate Integral from 0 to 1
  • MHB
  • Thread starter karush
  • Tags
    Integral
In summary: Let $f(x)= x^3$In summary, Karush, you are asked to find the area of a region bounded between the graphs of y = -1 and y = f(x) for x between -1 and 0, and between the graphs of y = 1 and y = f(x) for x between 0 and 1. If you graph this region, you get a just an interval of 0 to 1. To find the area of this region, you use an integral that corresponds to the area of the region. The answer is found by calculating the area of one section and doubling it.
karush
MHB
3,269
A region is bounded between the graphs of y = -1 and y = f(x) for x between -1 and 0, and between the graphs of y = 1 and y = f(x) for x between 0 and 1.
Give an integral that corresponds to the area of this region.
however the answer to this is $\int_0^1 2(1-x^3)dx$
if I graph this i get a just an interval of 0 to 1
Please post the entire question, preferably as asked.
In particular what is \(f(x)\)? Presumably \(f(x)=x^3\), but I am only guessing.
(If it is as I guess consider just one part of the graph and use symmetry to get the area for the other)
CB
Let $f(x)= x^3$
A region is bounded between the graphs of $y = -1$ and $y = f(x)$ for $x$ between $-1$ and $0$, and between the graphs of $y = 1$ and $y = f(x)$ for x between $0$ and $1$. Give an integral that corresponds to the area of this region.
OK, sorry, I left out the $f(x)$, this is exactly the way it was given, however not sure why they split the interval
Hello, karush!
I don't suppose you made a sketch . . .
A region is bounded between the graphs of: $y = \text{-}1,\;y = x^3$ on $[\text{-}1,0]$
. . and between the graphs of: $y = 1,\;y = x^3$ on $[0,1]$.
Code:
               1+ - - - - *
     -1         |:::*     |
      |     *:::|         1
              -1|
There are two sections to consider.
Since the two sections are symmetric (have equal areas)
. . we have find the area of one section and double.
[tex]A \;=\;2\int^1_0(1-x^3)\,dx[/tex]Why did they split the region?
Evaluate: .[tex]\int^1_{\text{-}1}(1-x^3)\,dx[/tex]. . and tell me what you get.
ok so if we take the full interval of -1 to 1 they cancel to zero but since the areas are = at the given intervals then the area of the -1 to 1 is just double or 2 times.
https://www.physicsforums.com/attachments/511
thanks and I will more careful with the OP
The integral of \(f(x)=x^3\) from \(-1\) to \(1\) is indeed zero, but that is not what you are asked to find. You are asked to find the area of a region, and if you look at soroban's post you will see a sketch of that region.
Also the way the question is worded you are not dealing with signed areas, so if it had specified the area in your diagram it would have been asking for:
\[A=\int_{-1}^0 (0-x^3)\; dx + \int_{0}^1 (x^3-0)\; dx=2 \int_{0}^1 (x^3-0)\; dx\]
CB
FAQ: Area Under Curve: Calculate Integral from 0 to 1
What is the area under the curve?
The area under the curve refers to the area enclosed by a curve on a graph and the x-axis, within a specific interval. It is commonly used in mathematics and science to find the total value or quantity of a function over a given range.
Why is it important to calculate the integral from 0 to 1?
The integral from 0 to 1 is important because it represents the total accumulation of a function over a specific interval. It is often used to calculate important values such as average, total, or maximum/minimum values in various applications.
How is the area under the curve calculated?
The area under the curve can be calculated using various methods, such as Riemann sums, trapezoidal rule, or Simpson's rule. These methods involve dividing the interval into smaller sections and approximating the area under the curve using geometric shapes like rectangles, trapezoids, or curves.
What are the applications of calculating the area under the curve?
The area under the curve has various applications in science, engineering, and economics. It is commonly used in physics to calculate work, in chemistry to determine reaction rates, and in finance to calculate the total profit or loss over a given period. It is also used in data analysis to find the total value of a variable over a specific time frame.
Can the area under the curve be negative?
Yes, the area under the curve can be negative. This occurs when the curve dips below the x-axis, resulting in negative values for the area enclosed. In such cases, the negative value represents a decrease or loss in the quantity being measured.
