Physiona
- 131
- 9
QUESTION:
The angles in triangle ABC form an increasing arithmetic sequence.
The ratio of angles A:B:C can be written in the form 185:370:555 respectively.
You are told that the total area of the triangle is 9
Length BC is
Given the area of triangle ABC, work out the value of
Give your answer in the form
where
and
are integers.
ATTEMPT:
I have decided to figure out a multiplier for all the angles provided, and labelled it as y
y(185+370+555)= 180
1110y = 180
y= 6/37
I am then planning on using the sine rule however, I don't have set values to use only angles. I'm not sure on whether or not my attempt is correct. Any guidance to helping? Thank you!
Length BC is
ATTEMPT:
y(185+370+555)= 180
1110y = 180
y= 6/37
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=units%7B%5C+%7D%5E%7B2%7D.png429 bytes · Views: 926
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=x%5C+units.png428 bytes · Views: 948
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=x.png214 bytes · Views: 954
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=x%3D%5Csqrt%7Ba%5Csqrt%7Bb%7D%7D.png544 bytes · Views: 921
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=a.png210 bytes · Views: 958
chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=b.png214 bytes · Views: 905
