MHB Arithmetic and geometric sequence
The discussion focuses on solving problems related to arithmetic and geometric sequences. For the arithmetic sequence, the 1st term is calculated as 58/5, and the 5th term is -98/5, with no term equating to -70. In the geometric sequence, the 3rd and 5th terms are derived from two potential sequences, yielding values of 8 and 32 for one sequence, and -8 and -32 for the other. The calculations involve determining common differences and ratios based on given terms. This analysis provides a clear understanding of the sequences in question.
paix1988
*I am struggling with arithmetic and geometric sequences.
if the 4th term is m-8, 6th term 8m+3 and 8th term is 10m-5
Calculate the 1st and 5th term
Which term will have a value of -70The 4th term of geometric sequence is -16 and the 6th term is -64. Calculate the 3rd and 5th terms.
thank you for your assistance
Mathematics news on Phys.org
Hello and welcome to MHB! paix1988 :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
For the benefit of the community, I am going to post solutions.
1.) We are given the following information regarding an arithmetic progression:
$$a_4=m-8,\,a_6=8m+3,\,a_8=10m-5$$
If we denote the common difference as $d$, then from this we know:
$$2d=(8m+3)-(m-8)=7m+11$$
$$2d=(10m-5)-(8m+3)=2m-8$$
Equating the two results, we obtain:
$$7m+11=2m-8\implies m=-\frac{19}{5}\implies d=-\frac{39}{5}$$
Now, in general, we have:
$$a_n=a_1+(n-1)d$$
And we know:
$$a_4=a_1+3d$$
$$m-8=a_1+3d$$
$$-\frac{59}{5}=a_1-\frac{117}{5}$$
$$a_1=\frac{58}{5}$$
Hence, the general term is:
$$a_n=\frac{58}{5}+(n-1)\left(-\frac{39}{5}\right)=\frac{58-39(n-1)}{5}$$
Thus, the 5th term is:
$$a_5=\frac{58-39(5-1)}{5}=-\frac{98}{5}$$
To find which term has a value of -70, we may write:
$$\frac{58-39(n-1)}{5}=-70$$
$$58-39(n-1)=-350$$
$$-39(n-1)=-408$$
$$n-1=\frac{136}{13}$$
We will not get an integral value for $n$, thus none of the terms of this AP has a value of -70.
2.)The $n$th term of a GP is:
$$a_n=ar^n$$
We know that:
$$\frac{g_6}{g_4}=\frac{-64}{-16}=4=r^2\implies r=\pm2\implies a=-1$$
Thus, there are two possible GPs satisfying the given information:
a) $$a_n=-(-2)^n\implies a_3=8,\,a_5=32$$
b) $$a_n=-2^n\implies a_3=-8,\,a_5=-32$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
