MHB Arithmetic Progression Challenge
Distinct positive integers \(a\), \(b\), and \(c\) can be found such that \(a+b+c\), \(ab+bc+ac\), and \(abc\) form an arithmetic progression, with the solutions being \((3, 6, 27)\) and \((3, 7, 16)\). The arithmetic progression condition leads to the equation \((a-2)(b-2)(c-2) = 3\sum a - 8\), which provides insights into the values of \(a\), \(b\), and \(c\). The analysis shows that at least one of the integers must be small, leading to the conclusion that \(a\) is likely \(3\). The distinct integers must satisfy the conditions derived from the arithmetic progression, confirming the validity of the solutions.
anemone
MHB
POTW Director
Find distinct positive integers $$a,\;b,$$ and $$c$$ such that $$a+b+c,\;ab+bc+ac,\;abc$$ forms an arithmetic progression.
Mathematics news on Phys.org
[sp]If $(a,b,c) = (3,6,27)$ then $a+b+c = 36$, $bc+ca+ab = 261$ and $abc = 486$. These numbers are in arithmetic progression.
I don't have a careful proof, but here is how I came across the solution (which I am fairly sure is unique). Write $\sum a$ for $a+b+c$ and $\sum bc$ for $bc+ca+ab$. Then $\sum a,\ \sum bc$ and $abc$ form an arithmetic progression, and therefore $\sum a - 2\sum bc + abc = 0.$ Hence $$\textstyle (a-2)(b-2)(c-2) = abc - 2\sum bc + 4 \sum a - 8 = 3\sum a - 8.$$
That equation tells you quite a lot. For a start, the product $(a-2)(b-2)(c-2)$ is congruent to $1\pmod3$, which means that either $a$, $b$ and $c$ are all multiples of $3$, or one of them is a multiple of $3$ and the other two are congruent to $1\pmod3$. Next, the product of the three numbers $a-2$, $b-2$, $c-2$ is only about three times their sum, so at least one of them must be rather small. You can easily rule out the possibility that the smallest of the numbers $a,\ b,\ c$ is $1$. So that makes it seem almost sure to be $3$. If you then put $a=3$ in the displayed equation, and use the fact the other two numbers must either both be multiples of $3$ or both congruent to $1\pmod3$, it does not take long to find the solution.[/sp]
2 more, Opal (keeping it a =< b =< c):
3,7,16 : 26,181,336 ; diff=155
4,4,24 : 32,208,384 ; diff=176
Good catch: I completely missed that one.
Not allowed! Those numbers are not distinct.
True...but that was a BONUS: I DID state: (keeping it a =< b =< c)(Ninja)
Thank you Opalg and Wilmer for participating...
My solution:
By continuing with what Opalg has mentioned in his post
Opalg said:
"Write $\sum a$ for $a+b+c$ and $\sum bc$ for $bc+ca+ab$. Then $\sum a,\ \sum bc$ and $abc$ form an arithmetic progression, and therefore $\sum a - 2\sum bc + abc = 0.$ Hence $$\textstyle (a-2)(b-2)(c-2) = abc - 2\sum bc + 4 \sum a - 8 = 3\sum a - 8.$$
That equation tells you quite a lot. For a start, the product $(a-2)(b-2)(c-2)$ is congruent to $1\pmod3$, which means that either $a$, $b$ and $c$ are all multiples of $3$, or one of them is a multiple of $3$ and the other two are congruent to $1\pmod3$. Next, the product of the three numbers $a-2$, $b-2$, $c-2$ is only about three times their sum, so at least one of them must be rather small. You can easily rule out the possibility that the smallest of the numbers $a,\ b,\ c$ is $1$. So that makes it seem almost sure to be $3$. If you then put $a=3$ in the displayed equation",
we could then rewrite the three consecutive terms of the arithmetic progression as $$3+b+c,\;\;3(b+c)+bc,\;\;3bc$$.
And the difference between terms is always the same for any arithmetic progression, we have
$$3bc-(3(b+c)+bc)=3(b+c)+bc-(3+b+c)$$
$$bc=5b+5c-3$$
$$b=\frac{5c-3}{c-5}=5+\frac{22}{c-5}$$
Since we're told that both $b$ and $c$ are distinct positive integers, this leads to only three possible values of $c-5$ that it could take as $22=1(22)=2(11)$.
If $$c-5=22\;\;\rightarrow c=27,\;b=6,\;\;a=3$$.
If $$c-5=2\;\;\rightarrow c=7,\;b=16,\;\;a=3$$.
If $$c-5=11\;\;\rightarrow c=16,\;b=7,\;\;a=3$$.
Hence, $(a, b, c)$=$(3, 6, 27)$ or $(3, 16, 7)$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
