B Arithmetic progression, Geometric progression and Harmonic progression
Arithmetic, geometric, and harmonic sequences can be used to build functions, but they are limited in scope. These sequences are defined by consistent numerical patterns, which can help create equations for specific types of functions. However, not all functions can be represented by these sequences, as they primarily apply to integers and exclude many continuous functions like polynomials or trigonometric functions. Examples such as f(x)=x^3 and g(x)=|x| illustrate that many functions do not fit within these progressions. Therefore, while sequences can aid in function creation, they do not encompass all possible functions.
pairofstrings
TL;DR Summary
It looks as if the AP, GP, HP can be used to build any function.
How do I build functions by using Arithmetic Sequence, Geometric Sequence, Harmonic Sequence?
Is it possible to create all the possible function by using these sequences?
Thanks!
Mathematics news on Phys.org
How do you "use a sequence to build a function"? What does that mean?
Sequences are numbers with common difference. f(x) is a sequence and g(x) is a sequence. If there is common difference then there is consistency among numbers. If there is consistency among numbers then I can build an equation.
Example:
The values in the second column of the below table have consistent numbers for given input 'x' for drawing a graph of f(x) or g(x) .
So the equation is:
y = f(x) = x + 2;
xf(x) = y
-20
-11
02
y = g(x) = 3x + 2
xg(x) = y
-3-7
-2-4
-1-1
02
311
So, all functions have consistent numbers?
What about this:
Not all functions are one of these progressions. First of all, these progressions are only defined for integers, so you'll never catch functions defined on other sets, like the real numbers. But it doesn't even work for integers. Simple counterexamples are f(x)=x3 or g(x)=|x| or h(x)=sin(x). The Gaussian distribution you posted is a counterexample, too. Only a very limited set of functions can be made with the three progressions you listed.
If there is a pattern of numbers that have consistent numbers in it then any function can be created. No?
No.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
