Arithmetic Progression question
I'm sorry, i do not understand how you solved that equation, or where the x's or the 25's went. I think you may have made a mistake, but don't worry. Instead, let's solve the equation from the beginning.25^x\ln25-25^{-x}\ln25+5(5^x\ln5)-5(5^{-x}\ln5)=0Multiply through by 25x to make things easier. Let y=5x25^{2x}\ln25-25^{-y}\ln25+5(25^y\ln5)-5(25^{-y}\ln5)=0And then we can substitute this back into our
Saitama
4,243
93
If x ε R, the numbers 51+x+51-x, a/2, 25x
+25-x form an AP, then 'a' must lie in the interval:-
a)[1,5)
b)[2,5]
c)[5,12]
d)[12,∞)
Not required
I substituted y=5x.
The terms are in AP, so the common difference is constant. That is:-
[tex]\frac{a}{2}-5y-\frac{5}{y}=y^2+\frac{1}{y^2}-\frac{a}{2}[/tex]
[tex]\Rightarrow a=y^2+\frac{1}{y^2}+5y+\frac{5}{y}[/tex]
Now i am stuck here. :(
Please somebody help.
Thanks! :smile:
Think about the domain of each variable. [itex]x\in R[/itex] thus [itex]y=5^x[/itex] is in which set? And what about a?
You may want to graph the function [tex]a=y^2+\frac{1}{y^2}+5y+\frac{5}{y}[/tex] to get an idea of what the answer might be.
Thanks for the reply Mentallic. :smile:
y=5x in (0,∞) set. Right?
Then a should also lie in the same set.
Can you tell me an other way except graphing? Because this question is from a test paper and i don't think graphing the function would do me any good because i suck at graphing. :D
a)[1,5)
b)[2,5]
c)[5,12]
d)[12,∞)
Not required
I substituted y=5x.
Thanks! :smile:
Now substitute 5x back in for y.
[itex]a=5^{2 x}+(5)5^{x}+(5)5^{-x}+5^{-2 x}[/itex]​
See if you can find a minimum and/or a maximum for this.
(It's an even function.)
Hi SammyS! :)
Even function? What do you mean by that?
And i am not sure about how to find maximum and minimum of a function. I just read it once.
Do we find minimum or maximum like this: First we take the derivative of the function and then substitute it to zero.?
Pranav-Arora said:
Hi SammyS! :)
Do we minimum or maximum like this: First we take the derivative of the function and then substitute it to zero.?
If you know how to take the derivative, then do that and set it equal to zero. (This is the precalculus section.)
An even function is one whose graph is symmetric with respect to the y-axis.
You can also represent this as the sum of two hyperbolic cosine functions.
5 = eln(5), so
[itex]\displaystyle a=5^{2 x}+5^{-2 x}+(5)5^{x}+(5)5^{-x}[/itex]
[itex]\displaystyle =e^{2 x\,\ln5}+e^{-2 x\,\ln5}+(5)e^{x\,\ln5}+(5)e^{-x\,\ln5}[/itex]
[itex]\displaystyle =2\cosh(2 x\,\ln5)+2(5)\cosh(x\,\ln5)[/itex]​
Now you can graph this.
5 = eln(5), so
Lol, i don't know about hyperbolic functions. :smile:
Sorry, but i did not know that we will have to use Calculus in this question, so i posted it in precalculus section. :)
Ok i go like this:-
I find the derivative of the given function which comes out to be:-
[tex]25^xlog_e25-25^{-x}log_e25+5(5^xlog_e5)-5(5^{-x}log_e5)[/tex]
When i substitute it to zero, i get stuck.. Here are the steps:-
[tex]log_e25(25^x-25^{-x})=-5log_e5(5^x-5^{-x})[/tex]
[tex]\frac{25^x-25^{-x}}{5^x-5^{-x}}=\frac{-5}{2}[/tex]
What should i do next?
Yes, that's right :smile:
Oh, yep ofcourse. Graphing calculators are just the cheap and brainless way of figuring out the answer anyway :wink:
Looking at the function [tex]a=5^{2x}+5^{-2x}+5^{1+x}+5^{1-x}[/tex]
finding a turning point for this function we set the derivative equal to zero. In short, by using the rational root theorem, you should find [itex]5^x=\pm 1[/itex] but 5x>0 so 5x=1 is the only valid solution, thus x=0 is where the turning point occurs. You can go further and show this is a minimum turning point, so at x=0, [itex]a=5^0+5^0+5^{1+0}+5^{1+0}=12[/itex] and clearly a is always increasing since all the powers are greater than zero, and 5x approaches infinite as x approaches infinite, so we have the answer.
Yes good work, that's correct.
Because you shouldn't be plugging in x=0, that will give you the gradient of the original function at x=0, what you instead want to do is solve the derivative equal to 0. Multiply through by 25x and to make things simpler, let y=5x. Then use the rational root theorem to find the roots.
We aren't allowed calculators during an exam. :smile:
Mentallic said:
Yes good work, that's correct.Because you shouldn't be plugging in x=0, that will give you the gradient of the original function at x=0, what you instead want to do is solve the derivative equal to 0. Multiply through by 25x and to make things simpler, let y=5x. Then use the rational root theorem to find the roots.
I did not plugged x=0, i solved the derivative equal to 0.
Sorry for my confusing English. :redface:
Here i go again:-
let y=5x
then continuing my above equation,
[tex]\frac{y^2-y^{-2}}{y-y^{-1}}=\frac{-5}{2}[/tex]
Solving i get:-
[tex]\frac{y^2+1}{y}=\frac{-5}{2}[/tex]
[tex]\Rightarrow 2y^2+5y+2=0[/tex]
Solving i get, y=-2 and -1/2.
that is, 5^x=-2 and -1/2.
This is funny, we need to have y>0. :D
I don't understand where i am wrong.
Bump :)
Ahh ok, then your problem lies elsewhere :-p
Pranav-Arora said:
Here i go again:-
let y=5x
Solving i get:-
How did you get from the first equation to the next? I suggest you get rid of the fractions, so that involves multiplying through by y2. You'll have a polynomial of degree 4 to solve, which is why I mentioned the rational root theorem.
You can see at once that a can go to infinity.
To find the minimum of a, find the derivative with respect to y. You did it with respect to x, but it differs only by a factor of 5xln(5)
You get the equation
[tex]2y-\frac{2}{y^3}+5-\frac{5}{y^2}=0[/tex]
factor out 5 and 2y:
[tex]5(1-\frac{1}{y^2})+2y(1-\frac{1}{y^4})=0[/tex]
Notice that [tex]1-\frac{1}{y^4}=(1-\frac{1}{y^2})(1+\frac{1}{y^2})[/tex]
[tex]5(1-\frac{1}{y^2})+2y(1-\frac{1}{y^2})(1+\frac{1}{y^2})=0[/tex]
[tex](1-\frac{1}{y^2})(5+2y(1+\frac{1}{y^2}))=0[/tex]
One solution is y2-1=, y=1. The other solution of
[tex]5+2y(1+\frac{1}{y^2})=0[/tex]
leads to negative roots, which are inappropriate. So the only extremum is at y=1, and it is minimum.
ehild
Lol, i have never used that theorem. :D
I think i will have to refer wiki.
ehild
Thank you ehild. I get it now.
I was getting only negative roots, now my problem is solved, thank you. :smile:
You are welcome.
Advice: never ever simplify with something which can be zero.
ehild
ehild said:
You are welcome.
ehild
Thanks for the advice.
I will remember that. :)
Related to Arithmetic Progression question
1. What is an Arithmetic Progression?
An Arithmetic Progression (AP) is a sequence of numbers in which the difference between any two consecutive terms is constant. This constant difference is called the common difference.
2. How do you find the nth term in an Arithmetic Progression?
The general formula for finding the nth term in an Arithmetic Progression is:
nth term = a + (n-1)d
where a is the first term and d is the common difference.
3. What is the sum of the first n terms in an Arithmetic Progression?
The sum of the first n terms in an Arithmetic Progression is given by:
Sn = (n/2)(2a + (n-1)d)
where a is the first term, d is the common difference, and n is the number of terms.
4. What are the applications of Arithmetic Progression?
Arithmetic Progression has various applications in mathematics, physics, and economics. It is used to model linear relationships and to calculate interest rates in financial investments.
5. How is Arithmetic Progression different from Geometric Progression?
Arithmetic Progression and Geometric Progression are both types of sequences, but they differ in their common difference (AP) and common ratio (GP). In an AP, the difference between consecutive terms is constant, while in a GP, the ratio between consecutive terms is constant. Additionally, AP has linear growth while GP has exponential growth.
