Arithmetic Sequence for homework,im also new to this website
In summary, the conversation discusses finding a way to prove that 2ab/(a+b), b, and 2bc/(b+c) are consecutive terms in an arithmetic sequence when a, b, and c are consecutive numbers in a geometric sequence. The attempt at a solution involves using the fact that b can be expressed as ar^2 and c as ar^3, and then dividing the last equation by ab as neither can be zero. The importance of parentheses is also mentioned.
Digital Genius
a, b and c are consecutive numbers in a geometric sequence, where a+b ≠ 0 and b+c ≠ 0
* "/" means divide *
Show that 2ab/a+b, b and 2bc/b+c are consecutive terms in an arithmetic sequence
i know this has something to do with it...
a,b,c GP
Show 2ab/a+b, b, 2bc/b+c ...
T1, T2, T3 of AP
T2-T1=T3-T2
b-(2ab/a+b)=(2bc/b+c) - b
b2 = ac
If you mean 2ab/(a+b), b , 2bc/(b+c) write it that way. Parentheses matter.
a,b,c GP
T1, T2, T3 of AP
T2-T1=T3-T2
b2 = ac
You haven't used the fact that a,b,c are a GP. That means ##b=ar^2,~c=ar^3##. Use that. Or you can divide that last equation by ab, assuming neither are zero.
a,b,c GP
T1, T2, T3 of AP
T2-T1=T3-T2
b2 = ac
What you wrote means
[tex] \frac{2ab}{a} + b \text{ and } \frac{2bc}{b}+c[/tex]
Is that what you wanted, or did you want
[tex] \frac{2ab}{a+b} \text{ and } \frac{2bc}{b+c}?[/tex]
Parentheses are important: if you mean ##\frac{A}{B+C}## you need to write it in text as A/(B+C).
FAQ: Arithmetic Sequence for homework,im also new to this website
What is an arithmetic sequence?
An arithmetic sequence is a list of numbers where the difference between consecutive terms is always the same. For example, 2, 4, 6, 8, 10 is an arithmetic sequence with a common difference of 2.
How do you find the common difference of an arithmetic sequence?
To find the common difference of an arithmetic sequence, subtract any two consecutive terms. The result will be the common difference. For example, in the sequence 2, 4, 6, 8, 10, the common difference is 4 - 2 = 2.
What is the formula for finding the nth term of an arithmetic sequence?
The formula for finding the nth term of an arithmetic sequence is:
an = a1 + (n-1)d
where an is the nth term, a1 is the first term, and d is the common difference.
How do you find the sum of an arithmetic sequence?
To find the sum of an arithmetic sequence, use the formula:
Sn = n/2(a1 + an)
where Sn is the sum of the first n terms, a1 is the first term, and an is the nth term.
How can I recognize an arithmetic sequence?
An arithmetic sequence can be recognized by looking for a pattern of a constant difference between consecutive terms. It can also be confirmed by using the formula for finding the nth term and checking that the result is the same for all terms in the sequence.
