Luigi Fortunati
- 47
In the arm-wrestling, when the hand A prevails on the hand B, the force of A on B is greater than that of B on A?
No. That would violate Newton's third law. The torque on the arm of B from the force from A is greater than the torque on the arm of B that B is able to generate.Luigi Fortunati said:In the arm-wrestling, when the hand A prevails on the hand B, the force of A on B is greater than that of B on A?
No, see also this:Luigi Fortunati said:In the arm-wrestling, when the hand A prevails on the hand B, the force of A on B is greater than that of B on A?
OK thanks.A.T. said:No, see also this:
http://www.lockhaven.edu/~dsimanek/physics/horsecart.htm
“Strength” is not a standard physics concept. Do not confuse it with force, which is.Luigi Fortunati said:OK thanks.
Therefore the force exerted by the hand A (also of the strongest man in the world) on the hand B, can never exceed (not even a little) the strength that the hand B exerts on the hand A (therefore represents its maximum limit).
I think you need to distinguish between the muscular force and the total force one hand exerts on the other.Luigi Fortunati said:OK thanks.
Arm-wrestling is a competitive sport where two individuals lock their hands together and try to force their opponent's arm down onto a table. It is a test of strength and technique.
The main muscles used in arm-wrestling are the biceps, triceps, forearm flexors, and forearm extensors. These muscles work together to generate force and control the movements of the arm.
Arm-wrestling demonstrates the concept of forces through the application of force from one individual to another. Each person is trying to overcome the force of their opponent and push their arm down onto the table. It also shows the importance of technique in utilizing forces effectively.
Yes, arm-wrestling can cause injuries if not done properly. Common injuries include strains and sprains in the muscles, tendons, and ligaments of the arm. It is important to warm up and use proper technique to reduce the risk of injury.
Arm-wrestling can be a fair test of strength if both individuals are of similar size and have similar technique. However, factors such as hand and arm size, grip strength, and technique can also play a role in determining the outcome of a match.
