Aromatic substitution and it's effect on proton NMR?
In summary: So in summary, the group ortho/para directing increases the nucleophilicity of the aromatic ring and affects the shielding of protons at the meta positions.
LogicX
181
I can't figure out how aromatic substituents effect aromatic rings. I can think of it in a couple ways:
Is the group ortho or meta directing? When we learned about aromatic electrophilic substitution, we obviously learned about these groups. When an aromatic proton is lost, it will be preferentially lost in a certain position due to the additional resonance of whatever group is attached to the ring. So this tells you where you can find extra positive charge on the ring (and thus where it would be more deshielded). For example, an ortho directing group would have more positive charge on the meta positions. This reasoning seems to work when I am doing problems.
However you aren't actually pulling off protons, you are just looking at their chemical environments. So take an ortho directing group like OH. The O is electronegative, so it should have a partial negative charge. If it has a partial negative charge then that means it drew electrons out of the aromatic system. So the whole thing would be deshielded, but maybe slightly less deshielded the further away you get from oxygen. This reasoning doesn't seem to work when doing problems.
So basically, if you take a neutral aromatic ring with a substituent on it such as an ortho/para director like -OH, is there actually deshielding occurring at the meta positions? We only learned about it in terms of resonance that could be drawn after you pulled a proton off and the ring had an overall +1 charge.
I guess this boils down to me not understanding when the inductive effect applies and when resonance stabilization applies.
Chemistry news on Phys.org
Consider the case of methoxybenzene shown below:
You can see that resonance will delocalize the lone pair on the oxygen into the aromatic ring. In this case, the oxygen is actually donating electron density to the aromatic ring. Hence, this and other ortho-/para-directing groups are also consider activating groups because they increase the nucleophilicity of the aromatic ring. While oxygen is electronegative and should remove electron density from the aromatic ring through the inductive effect, the resonance effect is stronger than the inductive effect, so the methoxy group overall donates electron density to the aromatic ring.
The increased electron density goes primarily to the ortho and para positions on the ring giving these positions a partial negative charge and increasing the shielding of the protons at those locations.
Thank you that was very helpful.
FAQ: Aromatic substitution and it's effect on proton NMR?
What is aromatic substitution?
Aromatic substitution is a type of organic reaction where an atom or group of atoms is replaced by another atom or group on an aromatic compound. This type of reaction is commonly observed in benzene and other aromatic compounds.
How does aromatic substitution affect proton NMR?
Aromatic substitution can affect proton NMR in several ways. It can cause changes in the chemical shift values of the protons on the substituted aromatic ring, as well as the splitting patterns of neighboring protons. This can provide valuable information about the structure and substitution pattern of the aromatic compound.
What are the different types of aromatic substitution?
The two main types of aromatic substitution are electrophilic and nucleophilic substitution. Electrophilic substitution involves the replacement of a hydrogen atom by an electrophilic species, while nucleophilic substitution involves the replacement of a leaving group by a nucleophile.
How does the position of substitution affect proton NMR?
The position of substitution on an aromatic ring can significantly affect the proton NMR spectrum. Substitution at different positions can result in different chemical shift values and splitting patterns, allowing for the identification of the substitution pattern of the compound.
What other factors can influence proton NMR in aromatic compounds?
In addition to substitution, other factors that can influence proton NMR in aromatic compounds include the presence of other functional groups, solvent effects, and temperature. These factors can all contribute to changes in the chemical shift and splitting patterns observed in the NMR spectrum.
