Arrange Numbers for Complete Squares Puzzle
In summary, there is a problem to arrange a set of numbers such that the summation of each two successive numbers is a complete square. Some possible solutions have been found through backtracking algorithms, but there is also interest in finding an analytical approach. For large enough n, there may be multiple solutions or none at all. This problem appears to be interesting and potentially deep, and it is speculated that the generalization of this problem may be NP-complete. Additionally, it has been observed that when n is close to 15, the solution often reuses the solution for n = 15 in some way. However, there are exceptions to this pattern. Finally, it has been noted that if there are three numbers in the set that
Amer
259
Arrange the numbers: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
such that the summation of each two successive numbers is a complete square easy interesting question
Mathematics news on Phys.org
8, 1, 15, 10, 6, 3, 13, 12, 4, 5, 11, 14, 2, 7, 9
I can think of a backtracking algorithm to solve this relatively efficiently given any input set. Might code it up tomorrow. Does anyone have a way to attack this analytically (again, for any input set, not just consecutive integers, and return any solution sequence - or none if there are none). An argument for the associated decision problem would be interesting to see too.
If n=2 k + 1 is a perfect square and the set is 1,2,..., 2k then is... 2 K + 1 = 2k-1 + 2 = 2 k -2 + 3 + ... = k+1 + k = n (1)Of course however that is a very particular case...Kind regards $\chi$ $\sigma$
I solved it too using
a matrix (I named my matrix A) with \(\displaystyle A_ab=1 if a+b=perfect square\)
It's pretty much done once you have the matrix, you see that 8 as the be the first (or last) number.
I ended with the same solution as MarkFL, and I was wondering if there is always a solution for n large enough?
and if that solution(if it exist) was unique?
I know that for this case with n =15 the solution is unique.
I'll take a look at it tomorow (right now I need to hit the bed) if someone find something before I do let me know!
There are actually two solutions for n = 15, forward and reverse (obviously). There are no others. Solutions are not guaranteed to exist. There are none for n = 16, for instance (checked myself). Curiously there apparently are solutions for n = 30 and n = 60 (unsure, I'll check later). I have been working on two versions of an algorithm but they always end up having exponential complexity, because I can't find a good algorithm. I might post my drafts once I come back from comp labs.
Actually my bad, I wrote the above in a hurry. n = 16 actually has solutions, namely:
(8, 1, 15, 10, 6, 3, 13, 12, 4, 5, 11, 14, 2, 7, 9, 16)
(16, 9, 7, 2, 14, 11, 5, 4, 12, 13, 3, 6, 10, 15, 1, 8)
n = 17 has the following solutions:
(17, 8, 1, 15, 10, 6, 3, 13, 12, 4, 5, 11, 14, 2, 7, 9, 16)
(16, 9, 7, 2, 14, 11, 5, 4, 12, 13, 3, 6, 10, 15, 1, 8, 17)
n = 18 to n = 22 have no solutions.
n = 23 has the following solutions:
(22, 3, 1, 8, 17, 19, 6, 10, 15, 21, 4, 12, 13, 23, 2, 14, 11, 5, 20, 16, 9, 7, 18)
(18, 7, 2, 23, 13, 12, 4, 21, 15, 10, 6, 19, 17, 8, 1, 3, 22, 14, 11, 5, 20, 16, 9)
(2, 23, 13, 12, 4, 21, 15, 10, 6, 19, 17, 8, 1, 3, 22, 14, 11, 5, 20, 16, 9, 7, 18)
(9, 16, 20, 5, 11, 14, 22, 3, 1, 8, 17, 19, 6, 10, 15, 21, 4, 12, 13, 23, 2, 7, 18)
(18, 7, 9, 16, 20, 5, 11, 14, 2, 23, 13, 12, 4, 21, 15, 10, 6, 19, 17, 8, 1, 3, 22)
(18, 7, 9, 16, 20, 5, 11, 14, 22, 3, 1, 8, 17, 19, 6, 10, 15, 21, 4, 12, 13, 23, 2)
There will always be an even number of solutions, obviously.
Looks mysterious :confused:
An observation is that for n close to 15, the solutions tend to reuse the existing solution for n = 15 in some way (here 16 is added at the end, and after that 17 is added at the beginning), which I guess makes sense heuristically. The pattern breaks down for n = 23 though, there are bits of the original solution e.g. (8, 1, 15) but overall it changes quite a bit.
This is actually an interesting and deep problem. I wonder if it's NP-complete :p (probably not, if we limit ourselves to inputs of the form {1, 2, 3, ..., n} there should be an efficient way to find solutions. wouldn't surprise me if the full generalization is NP-complete though)
if we have three numbers in the given set that just has one mate from the set ( i mean by the mate, the summation of the two mates is a complete square ) then we can't order them
in our set 1,2,3,...,15
we have two such numbers which will be at the ends of the arrangement 9,8
for example 1,2,3,4,...,10
we can't order it since 10,9,8 has one mate
FAQ: Arrange Numbers for Complete Squares Puzzle
What is the "Arrange Numbers for Complete Squares Puzzle"?
The "Arrange Numbers for Complete Squares Puzzle" is a mathematical puzzle that involves arranging a set of numbers in a specific order to form a complete square.
How do you solve the "Arrange Numbers for Complete Squares Puzzle"?
To solve the puzzle, you need to arrange the given set of numbers in a way that they form a complete square when read from left to right and top to bottom. This can be achieved by using trial and error or by following a specific algorithm.
What is the significance of the "Arrange Numbers for Complete Squares Puzzle" in mathematics?
The puzzle is significant as it helps in developing logical thinking and problem-solving skills. It also introduces the concept of perfect squares and their properties to students.
Can the "Arrange Numbers for Complete Squares Puzzle" be solved using any set of numbers?
Yes, the puzzle can be solved using any set of numbers as long as they follow the rules of forming a complete square when arranged in a specific order.
Are there any real-life applications of the "Arrange Numbers for Complete Squares Puzzle"?
The puzzle has applications in various fields such as computer science, cryptography, and coding theory. It is also used in educational settings to teach mathematical concepts and problem-solving strategies.
