A Array variable of envelope function (parameter representation)
The discussion focuses on the envelope function in parameter representation for an array of curves defined by parameters 𝑑 and 𝑐. The condition for the envelope is established through a differential equation involving partial derivatives of the curve functions. A key question arises about how to limit the array variable 𝑐 to a specific range, such as from 0.5 to 1.0, instead of considering all values. Clarifications are made regarding the terminology used, particularly the concept of an "array variable" and its differentiation. The conversation concludes with a suggestion to redefine the curves in terms of specific parameters to address the query about restricting the envelope to a subset of curves.
mk3
Hi, I have a question regarding the envelope function in parameter representation.
Let an array of curves in cartesian coordinates be given in parameter representation, with curve parameter 𝑑 and array variable 𝑐
π‘₯=π‘₯(𝑑,𝑐)
𝑦=𝑦(𝑑,𝑐)
Condition for envelope is:
πœ•/πœ•π‘‘ π‘₯(𝑑,𝑐) πœ•/πœ•π‘ 𝑦(𝑑,𝑐)=πœ•/πœ•π‘ π‘₯(𝑑,𝑐) πœ•/πœ•π‘‘ 𝑦(𝑑,𝑐)
Solving this equation will give a relationship how the array variable 𝑐 depends on the curve parameter 𝑑 along the envelope:
𝑐_𝑒𝑛𝑣 (𝑑)=Ξ¨(𝑑)
But now here comes the question.
What if i want not the envelope of all array variables. Instead I want for example c from 0.5...1.0. How can I consider this in the function?
The target would be to give a limit for c.
Would be great to get a hint for that.
BG
MK
Mathematics news on Phys.org
When you say 'envelope function' are you talking about this or this?
What do you mean by 'array' and 'array variable'?
What do you mean by ## \dfrac \partial {\partial c} ##? You have said that ## c ## is an 'array variable'; whatever that is it doesn't sound like something you could differentiate with respect to.
Ok, now you've completely lost me: what is an 'array variable' that can take non-integer values?
Oh I think I see where the confusion lies, let me check.
You are talking about the envelope of a family of curves. We don't call this an 'envelope function' because the envolope is often not a function.
I think you are confused by the reference to a 'parameter' in relation to the family of curves. This has nothing to do with any parametric representation of individual curves within the family. I am not sure where you learned this stuff from but I think you need to go back over it.
When you have done that you should see that your final question translates to "what if i want not the envelope of all curves in the family. Instead I want for example the curves defined by the parameter ## c \in [0.5, 1 ]##?"
You should be able to answer this question by considering the definition of an envelope as a curve satisfying $$ F(c, x, y) = \dfrac \partial {\partial c} F(c, x, y) = 0 $$
If we restrict the values of ## c ## to a range then how does this affect the curve?
Note that I have kept to your use of the parameter ## c ## instead of the more usual ## t ##. Also rather than writing ## x = x(c, t) ## etc it would be better to specify an individual member of the family of curves as
f_c = \begin{cases}
x = x_c(t) \\
y = y_c(t)
\end{cases}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
