rubenhero
- 42
- 2
Write a MIPS assembly language program that accomplishes the following tasks:
1. The program will prompt the user to enter an Integer between 1 and 10.
If the entered number doesn’t satisfy the above condition, use a loop and prompt the
user for a new entry (until a valid number is entered)
2. Depending on the n value implement the following cases:
case 1: if 1< = n < = 6 compute F(n): if (n=1 or n=2) then F(n) = 10
else F(n) = 2n*F(n-1);
Display a result_message together with the numeric value of the result.
NOTE: use recursive function call.
case 2: if 7 <= n < 10
1. Declare an array of 10 elements.
2. Prompt the user to enter one by one a sequence of 10 characters. For each entered
character:
a. Read in the character.
b. Display the character.
3. Display the contents of the array in reverse order.
Your program should be well documented with comments.
Your console output should include helpful prompts for the user.
Case 3: if n = 10
Display a joke.
Code:
.text
addi $s0, $zero, 0 # register to transfer the user input.
addi $s1, $zero, 10 # register to hold integer value 10.
addi $s2, $zero, 2 # register to hold integer value 2.
addi $s3, $zero, 0 # initialize register for store of multiplication.
addi $s4, $zero, 0 # initialize register for case1b result.
addi $t0, $zero, 0 # initialize register for store of lower 32 bits of multiplication.
addi $t1, $zero, 0 # initialize register for store of lower 32 bits of multiplication 2nd time.
addi $t9, $zero, 0 # initialize register for array.
LOOP0:
la $a0, Prompt # load Prompt string into $a0.
li $v0, 4 # system call to print Prompt string.
syscall
li $v0, 5 # system call to read integer from user.
syscall
bgt $v0, 10, LOOP0 # branch if greater than 10, force user to enter lower number.
blt $v0, 1, LOOP0 # branch if less than 1, force user to enter a positive number.
ble $v0, 6, CASE1 # branch to CASE1 if input is less than or equal to value 6.
blt $v0, 10, CASE2 # branch to CASE2 if input is less than value 10.
beq $v0, 10, CASE3 # branch to CASE3 if input value is equal to value 10.
CASE1: # CASE1
move $s0, $v0 # move the input value from $v0 to $s0.
ble $s0, 2, CASE1A # branch to CASE1A if $s0 (the input value) is less than or equal to 2.
ble $s0, 6, CASE1B # branch to CASE1B if s$0 is less than or equak to 6.
CASE1A: # CASE1A
la $a0, MSG1 # Load MSG1 string to $a0.
li $v0, 4 # system call to print MSG1 string.
syscall
la $a0, 0($s1) # Load $s1 to $a0, the value is 10.
li $v0, 1 # system call to print the integer.
syscall
j EXIT # jump to EXIT.
CASE1B:
mult $s0, $s2 # multiply $s0 by $s2.
mfhi $v0 # move the upper 32 bits to $v0.
mflo $v1 # move the lower 32 bits to $v1.
move $t0, $v1 # move $v1 to $t0.
addi $s3, $s0, -1 # $s3 = $s0 - 1 or n-1.
mult $s3, $s2 # multiply $s3 by $s2 or 2(n-1).
move $t1, $v1 # move $v1 to $t1.
mult $t0, $t1 # multiply $t0 by $t1.
move $s4, $v1 # move $v1 to $s4
la $a0, MSG1 # Load MSG1 string into $a0.
syscall
la $a0, 0($s4) # Load $s4 into $a0.
li $v0, 1 # system call to print integer.
syscall
CASE2:
la $s7, ARRAY # Load base address of array into $t9
li $s6, 36 # Initialize loop counter to 36
LOOP:
la $a0, Prompt2 # Load Prompt2 string into $a0.
li $v0, 4 # system call to print string Prompt2.
syscall
li $v0, 12 # read character input.
syscall
move $s6($s7), $v0 # move input character to an array element.
la $a0, $s6($s7) # load array element into $a0.
li $v0, 11 # system call to print array element.
syscall
addi $s6, $s6, -4 # decrement loop counter.
bgtz $s6, LOOP
la $a0, MSG2 # load MSG2 string into $a0.
li $v0, 4 # system call to print MSG2 string.
syscall
LOOP2:
la $a0, $s6($s7) # load element of array into $a0.
li $v0, 11 # system call to print char.
addi $s6, $s6, 4 # increment $t8.
blt $s6, 36, LOOP2 # branch if $t8 is less than 36
j EXIT # when $t8 reaches 36 jump to EXIT.
CASE3:
la $a0, JOKE # Load JOKE string into $a0.
li $v0, 4 # system call to print JOKE string.
syscall
EXIT: # EXIT
li $v0, 10 # system call to exit the program.
syscall
.data
Prompt: .asciiz "Enter an integer between 1 and 10: "
MSG1: .asciiz "\nThe result is: "
MSG2: .asciiz "\nThe reverse is: \n"
Prompt2:.asciiz "\nEnter a character: "
JOKE: .asciiz "\nAdam and Eve Virus: Takes a couple of bytes out of your Apple\n"
ARRAY: .space 10 # 10 bytes of storage to hold an array of 10 characters
I got the program to respond to inputs 1,2,10 but 3,4,5,6,7,8,9 aren't producing the outputs that i need.
I think it might be the part where i move the input into the array. The recursive function part has been difficult for me.
Any suggestions and help would be greatly appreciated.
