AS Physics - Polarisation Problems.
In summary, the conversation discusses the concepts of light polarization and how it is affected when reflected off a surface. The speaker also asks about the intensity of light vibrations in each direction and how it changes when viewed through a polarizing filter. The expert summarizer explains that the intensity of light changes because it is partially polarized when reflected and that this effect is used in photography and sunglasses. The speaker also asks about the intensity change when the light is not reflected but directly passed through a polarizing filter. The expert clarifies that unpolarized light contains equal amounts of each polarization, and the intensity change is due to the different reflectivities of the two polarizations. Lastly, the speaker expresses gratitude for the reply and the expert provides additional information on
JediArron
Hey guys.
I need some help on understand a few concepts and have some questions
1. How is light polarised when it is reflected?
2. Are there different amounts of light vibrating in each direction, or is it equal?
3. From my revision guide:
"If you direct a beam of unpolarised light at a reflective surface then view the reflected ray through a polarising filter, the intensity of the light leaving the filter changes with the orientation of the filter.
The intensity changes because light is partially polarised when it is reflected.
This effect is used to remove unwanted reflections in photography, and in Polaroid sunglasses to remove glare."
- But wouldn't the light intensity leaving the filter change if it wasn't reflected off a surface, and just fired directly through a polarising filter? (Providing that each direction of vibration contains different amounts of light intensity)
- How is the intensity changing due to the light being partially polarised when it is reflected? I thought that it might be because there are different amounts of vibrations and/or light intensity in each direction?
Thank you for taking the time to read this and reply. It's much appreciated.
Welcome to Physics Forums.
JediArron said:
Hey guys.
The two polarizations have different reflectivities (except at normal incidence), so a reflected beam will have different amounts of power in the two polarization directions.
See above.
Unpolarized light contains the same amount of each polarization. So if "each direction of vibration contains different amounts of light intensity", then it is partially polarized, and not unpolarized.
As I said earlier, the two polarizations have different reflectivities, except at normal incidence.
You're welcome :smile:
EDIT: For more info, you can google "fresnel coefficients".
Related to AS Physics - Polarisation Problems.
1. What is polarisation in physics?
Polarisation in physics refers to the orientation of electromagnetic waves, which can be thought of as the direction in which the waves are oscillating. This can be either linear or circular polarisation, where the electric field vector of the wave is constrained to a specific direction.
2. How is polarisation measured?
Polarisation is typically measured using a polarimeter, which is a device that can determine the orientation of polarised light by analyzing the intensity of light transmitted through a polarizer. Another common method is using a polarizing filter, which blocks certain orientations of light and allows only a specific polarisation to pass through.
3. What are some applications of polarisation in physics?
Polarisation has many practical applications in physics, such as in optical instruments like microscopes and cameras, as well as in polarized sunglasses. It is also important in telecommunications, as it allows for the transmission of polarised signals over long distances without interference.
4. How does polarisation affect the perception of light?
When light is polarised, it can significantly affect how we perceive it. For example, polarised light can appear to be brighter or darker depending on the angle of polarisation and the material it is passing through. It can also affect the colors we see, making them appear more saturated or desaturated.
5. What are some common problems encountered with polarisation in physics?
One common problem encountered with polarisation is cross-polarisation, where the polarisation of a signal gets changed or distorted when traveling through certain materials or environments. Another issue is depolarisation, where the polarisation of a wave is lost due to scattering or interference. These problems can affect the accuracy of measurements and data in experiments.
  • Materials and Chemical Engineering
