phymatter
- 131
as temperature of a conductor increases why does the ratio of conductivity to resistivity increase ?
The ratio of temperature and conductor refers to the relationship between the temperature of a conductor and its electrical resistance. As the temperature of a conductor increases, its electrical resistance also increases.
This change is due to the atomic structure of the conductor. As the temperature increases, the atoms in the conductor vibrate more, causing more collisions and obstacles for the electrons to flow through, resulting in an increase in resistance.
Yes, there is an equation known as the temperature coefficient of resistance (TCR) that quantifies the change in resistance with temperature. It is represented by the symbol alpha (α) and is different for each type of conductor.
The change in resistance with temperature can impact the performance of electronic devices. Higher resistance can lead to higher power consumption, decreased efficiency, and even damage to the device if not properly managed.
While the change in resistance with temperature is a natural phenomenon, it can be controlled to some extent through the use of materials with low TCR or by implementing cooling systems to maintain a lower temperature of the conductor.
