Ashcroft & Mermin, Solid State Physics, Chapter 16, Problem 2
T}\left( -\nabla T \right) \right]4. Finally, equate this equation with the one from step 1 to get:\tau \left( \mathrm{ }\!\!\varepsilon\!\!\text{ }\left( \mathbf{k} \right) \right)\left( -\frac{\partial f}{\partial \mathrm{ }\!\!\varepsilon\!\!\text{ }} \right)\mathbf{v}\left( \mathbf{k} \right)\cdot \left[ -e\mathbf{\v
Denver Dang
148
Solving Boltzmann equation
Taken from Ashcroft & Mermin, Solid State Physics, Chapter 16, Problem 2:
"A metal is perturbed by a spatially uniform electric field and temperature gradient. Making the relaxation-time-approximation (16.9) (where g0 is the local equilibrium distribution appropriate to the imposed temperature gradient), solve the Boltzmann equation (16.13) to linear order in the field and temperature gradient, and verify that the solution is identical to (13.43)."
Eq. 16.9:
[tex]{{\left( \frac{\partial g}{\partial t} \right)}_{coll}}\simeq -\frac{\left[ g\left( \mathbf{k} \right)-{{g}_{0}}\left( \mathbf{k} \right) \right]}{\tau \left( \mathbf{k} \right)}[/tex]
Eq. 16.13:
[tex]\frac{\partial g}{\partial t}+\mathbf{v}\cdot \frac{\partial g}{\partial \mathbf{r}}+\mathbf{F}\cdot \frac{1}{\hbar }\frac{\partial g}{\partial \mathbf{k}}={{\left( \frac{\partial g}{\partial t} \right)}_{coll}}[/tex]
Eq. 13.43:
[tex]g\left( \mathbf{k} \right)={{g}_{0}}\left( \mathbf{k} \right)+\tau \left( \mathrm{ }\!\!\varepsilon\!\!\text{ }\left( \mathbf{k} \right) \right)\left( -\frac{\partial f}{\partial \mathrm{ }\!\!\varepsilon\!\!\text{ }} \right)\mathbf{v}\left( \mathbf{k} \right)\cdot \left[ -e\mathbf{\varepsilon }+\frac{\mathrm{ }\!\!\varepsilon\!\!\text{ }\left( \mathbf{k} \right)-\mu }{T}\left( -\nabla T \right) \right][/tex]
Well, I'm kinda lost. I put Eq. 16.9 into 16.13, and then what?
Can't really see how I get from the Boltzmann equation, with the relaxation-time-approximation, to 13.43 :/
So anyone who can help?
Thanks in advance.
Solving the Boltzmann equation can be a tricky task, but with the relaxation-time-approximation and some linear approximation, the solution can be simplified. Here are the steps to solve the problem:
1. Start by substituting Eq. 16.9 into Eq. 16.13 to get:
\frac{\partial g}{\partial t}+\mathbf{v}\cdot \frac{\partial g}{\partial \mathbf{r}}+\mathbf{F}\cdot \frac{1}{\hbar }\frac{\partial g}{\partial \mathbf{k}}=-\frac{\left[ g\left( \mathbf{k} \right)-{{g}_{0}}\left( \mathbf{k} \right) \right]}{\tau \left( \mathbf{k} \right)}
2. Next, use the linear approximation for the electric field and temperature gradient, assuming they are small, to get:
\mathbf{F}\cdot \frac{1}{\hbar }\frac{\partial g}{\partial \mathbf{k}}\simeq -e\mathbf{\varepsilon }\cdot \left( -\frac{\partial f}{\partial \mathrm{ }\!\!\varepsilon\!\!\text{ }} \right)\mathbf{v}\left( \mathbf{k} \right)\cdot \left[ -e\mathbf{\varepsilon }+\frac{\mathrm{ }\!\!\varepsilon\!\!\text{ }\left( \mathbf{k} \right)-\mu }{T}\left( -\nabla T \right) \right]
3. Now, substitute g(k) from Eq. 13.43 into the above equation to get:
\mathbf{F}\cdot \frac{1}{\hbar }\frac{\partial g}{\partial \mathbf{k}}\simeq \tau \left( \mathrm{ }\!\!\varepsilon\!\!\text{ }\left( \mathbf{k} \right) \right)\left( -\frac{\partial f}{\partial \mathrm{ }\!\!\varepsilon\!\!\text{ }} \right)\mathbf{v}\left( \mathbf{k} \right)\cdot \left[ -e\mathbf{\varepsilon }+\frac{\
FAQ: Ashcroft & Mermin, Solid State Physics, Chapter 16, Problem 2
What is the topic of Chapter 16 in Ashcroft & Mermin's Solid State Physics?
The topic of Chapter 16 is "Phonons: Normal Modes of Lattices". This chapter focuses on the study of lattice vibrations and how they contribute to the thermal and mechanical properties of solids.
What is the problem statement for Problem 2 in Chapter 16?
The problem statement for Problem 2 asks the reader to derive the expression for the dispersion relation of a one-dimensional monatomic chain with a basis of two atoms per unit cell, using the second quantization formalism.
What is the significance of the dispersion relation in solid state physics?
The dispersion relation describes the relationship between the energy and momentum of a particle in a solid. In solid state physics, it is used to understand the behavior of electrons, phonons, and other particles in the crystal lattice.
How does the number of atoms per unit cell affect the dispersion relation?
The number of atoms per unit cell can affect the dispersion relation in multiple ways. For example, in a one-dimensional monatomic chain, a basis of two atoms per unit cell results in a dispersion relation with two branches, representing the two types of lattice vibrations. In general, the number of atoms per unit cell can affect the shape and complexity of the dispersion relation.
Can the dispersion relation be experimentally measured?
Yes, the dispersion relation can be experimentally measured using techniques such as inelastic scattering, neutron scattering, and Raman spectroscopy. These methods allow for the direct observation of the energy and momentum of particles in a solid, providing information about the dispersion relation.
