MHB [ASK] A Line Intercepting A Circle
  • Thread starter Thread starter Monoxdifly
    Circle Line
A circle with center at (2, 1) intersects the line represented by the equation 3x + 4y + 5 = 0 at points A and B, with the distance AB measuring 8. The discussion reveals that the correct equation of the circle is not among the provided options, as none of them touch the line when checked with Desmos. To find the correct equation, one must calculate the distance from the circle's center to the line and use the properties of an isosceles triangle formed by the radius and the segment AB. The radius must be greater than 4, indicating that the radius squared exceeds 16. The thread concludes with a consensus that the initial options do not yield a valid circle equation.
Monoxdifly
MHB
A circle whose center is (2, 1) intercepts a line whose equation is 3x + 4y + 5 = 0 at point A and B. If the length of AB = 8, then the equation of the circle is ...
A. $$x^2+y^2-24x-2y-20=0$$
B. $$x^2+y^2-24x-2y-4=0$$
C. $$x^2+y^2-12x-2y-11=0$$
D. $$x^2+y^2-4x-2y+1=0$$
E. $$x^2+y^2-4x-2y+4=0$$
I don't know how to do it. Judging by the center of the circle, the answer must be either D or E. However, when I checked both of them with Desmos, neither circles even touches the line. How should I do it? Even if there's no right option, I would still like to know in case I encounter this kind of question again.
Mathematics news on Phys.org
Beer induced reaction follow.
https://www.desmos.com/calculator/ngflni4a1s
Find the distance $h$ from the circle center $O$ to the line using this formula. Then you have an isosceles triangle with base $AB=8$ and height $h$. Find the equal legs of the triangle, which is the radius of the circle.
I don't see the correct answer in any of the variants. I believe the red circle on your sketch is the correct one.
$(x-2)^2 + (y-1)^2 = r^2$
$AB = 8 \implies r >4 \implies r^2 > 16$
Okay, thank you for all your answers. :)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
