MHB [ASK] Debit: Determining Flow Rates In/Out Of Container
  • Thread starter Thread starter Monoxdifly
    Container Flow
The discussion focuses on calculating the flow rates of three water channels filling and emptying a tub. Channels I and II together fill the tub in 1 hour and 12 minutes, while Channel III empties it. By establishing equations based on the flow rates, the correct flow rates were determined: Channel I at 1/120 tubs per minute, Channel II at 1/180 tubs per minute, and Channel III at 1/720 tubs per minute. The calculations confirm that Channel III does not empty the tub in just 8 minutes, as initially speculated. The thread emphasizes the importance of accurately defining flow rates for proper understanding of the system.
Monoxdifly
MHB
A water tub has 3 water channels. Channel I and II for filling the tub and channel III to empty it. Those 3 channels together fulfill the tub for 1 hour and 20 minutes. Channel I and II together fulfill the tub for 1 hour and 12 minutes from the empty condition. Channel II and III together fulfill the tub for 4 hours from the empty condition. The duration of each channel I and channel II fulfill the tub and channel III empties the tub are...
Well, I don't know where to start. But if channel I and II together (without channel III being open) fulfill the tub in 1 hour and 12 minutes, does it mean that channel III can empty the tub just within 8 minutes (because 01.20 - 01.12)?
Mathematics news on Phys.org
Re: [ASK] Debit
This question was cross-posted on another site, where I responded:
I would begin by defining $C_1,\,C_2,\,C_3$ as the flow rates of the 3 channels, in tubs per minute.
From the given information, we know:
$$C_1+C_2-C_3=\frac{1}{80}\tag{1}$$
$$C_1+C_2=\frac{1}{72}\tag{2}$$
$$C_2-C_3=\frac{1}{240}\tag{3}$$
Suppose you subtract (3) from (1)...what do you get?
The OP correctly deduced:
$$C_1=\frac{1}{120}$$
$$C_2=\frac{1}{180}$$
$$C_3=\frac{1}{720}$$
I wish I had seen the thread here first. :p
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
