MHB [ASK] Equation of a Circle in the First Quadrant
  • Thread starter Thread starter Monoxdifly
    Circle
The center of circle L is located in the first quadrant on the line y = 2x, with the circle touching the Y-axis at (0, 6). The coordinates of the center can be determined as (3, 6) since the y-coordinate is derived from the tangential relationship to the Y-axis. The equation of the circle can be formulated as (x - 3)² + (y - 6)² = 3², leading to the simplified equation x² + y² - 6x - 12y + 36 = 0. The discussion also clarifies the correct use of "lies" versus "lays" in this context. The final equation represents the circle's properties accurately based on the given conditions.
Monoxdifly
MHB
The center of circle L is located in the first quadrant and lays on the line y = 2x. If the circle L touches the Y-axis at (0,6), the equation of circle L is ...
a. $$x^2+y^2-3x-6y=0$$
b. $$x^2+y^2-12x-6y=0$$
c. $$x^2+y^2+6x+12y-108=0$$
d. $$x^2+y^2+12x+6y-72=0$$
e. $$x^2+y^2-6x-12y+36=0$$
Since the center (a, b) lays in the line y = 2x then b = 2a.
$$(x-a)^2+(y-b)^2=r^2$$
$$(0-a)^2+(6-b)^2=r^2$$
$$(-a)^2+(6-2a)^2=r^2$$
$$a^2+36-24a+4a^2=r^2$$
$$5a^2-24a+36=r^2$$
What should I do after this?
Mathematics news on Phys.org
circle center at $(x,2x)$
circle tangent to the y-axis at $(0,6) \implies x=3$
$(x-3)^2+(y-6)^2 = 3^2$
$x^2-6x+9+y^2-12y+36 =9$
How did you get x = 3 from (0, 6)?
The fact that the y-axis is tangent to the circle at (0, 6) means that the line y= 6 is a radius so the y coordinate of the center of the circle is 6. And since the center is at (x, 2x), y= 2x= 6 so x= 3.
(And the center of the circle "lies on the line y= 2x", not "lays".)
Well, I admit I kinda suck at English. I usually use "lies" as "deceives" and "lays" as "is located". Thanks for the help, anyway. Your explanation is easy to understand.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
