MHB Ask for hint for problem of inequality
  • Thread starter Thread starter anemone
    Inequality
The discussion centers on proving the inequality x^2 + y^2 ≤ 1 given that x and y are positive real numbers satisfying x^3 + y^3 ≤ x - y. Participants explore various approaches, including factoring the left-hand side and applying theorems related to inequalities. A key point raised is the relationship between x and y, particularly that x > y, which leads to constraints on their values. The conversation also highlights the importance of understanding the implications of the theorem used in the proof. Ultimately, the conclusion is reached that x^2 + y^2 must indeed be less than or equal to 1 under the given conditions.
anemone
MHB
POTW Director
Problem:
Let x and y be positive real numbers satisfying the inequality $\displaystyle x^3+y^3\le x-y$.
Prove that $\displaystyle x^2+y^2\le 1$ .
Hi all, I'm at my wit's end to prove the question as stated above, and I know it's obvious that $\displaystyle x-y>0$ and $\displaystyle x\ne1,\,y\ne1$, and if I factorized the LHS of the given inequality, I get:
$\displaystyle (x+y)(x^2-xy+y^2)\le x-y$
Now, since $\displaystyle x+y>0$, divide the left and right side by $\displaystyle x+y$ to get:
$\displaystyle x^2-xy+y^2\le\frac{x-y}{x+y}$
$\displaystyle x^2+y^2\le\frac{x-y}{x+y}+xy$
$\displaystyle x^2+y^2\le\frac{x-y+xy(x+y)}{x+y}$
And up to this point, I see no credible path to finish what I've started and I must be missing something very important here...:mad:
As usual, any guidance or help with this problem would be much appreciated.(Smile)
Thanks.
Mathematics news on Phys.org
\frac{x - y}{x + y} \leq 1
So $x^2 + y^2 \leq 1 + xy$ .
Theorem:
Given real numbers $a = x^2 + y^2$ and $b = 1$ such that
a\leq b + \varepsilon,\quad \forall\varepsilon > 0.
Then $a\leq b$.
Theorem:
a\leq b + \varepsilon,\quad \forall\varepsilon >0
Then $a\leq b$.
Thank you so much for answering to my question, but, I understand that the theorem is true iff $\varepsilon $ is small , and how do we know we have a small value of xy in this case?
Suppose on the contrary that $b<a$, then let $\varepsilon = \frac{a - b}{2}$ (which may not be infinitesimal small).
b + \varepsilon = b + \frac{a - b}{2} = \frac{a + b}{2} < \frac{a + a}{2} = a
which is a contradiction.
Therefore, $a\leq b$.
Albert said:
Let $x=y=\frac{1}{2}$.
0\leq\frac{3}{4}\leq\frac{17}{16}\leq 1\leq 2
which isn't true.
Also, x and y can be any real number it says in post 1.
x,y are positive real numbers
$ x^3 +y^3 >0 $
$ so\,\, x\neq y$ (in fact x>y)
x,y be real numbers and meet the given restriction ,so at first I find the range of x and y then prove it will satisfy the inequility
(it is clear x,y can't be any real numbers)
$ x^3 +y^3 >0 $
Pick up Tom Apostles Real Analysis book. The theorem I stated was for all real numbers not just less than 1
Here is another method to prove the inequality $$x^2+y^2 \le1$$ given $$x^3+y^3\le x-y$$ for all real $x$ and $y$. I just saw this solution from another site and immediately wanted to add that solution here...
$$x^3+y^3\le x-y$$ tells us $$0\le y \le x$$.
Thus, we have $$ x^3\le x$$ and this implies $$x \le 1$$ and $$0\le y \le x \le 1$$.
In particular, $$x(x+y) \le 1(2) \le 2\;\;\rightarrow\;\;xy(x+y) \le 2y$$.
Finally, $$x^3+y^3=(x+y)(x^2-xy+y^2) \le x-y$$, so
$$x^2-xy+y^2 \le \frac{x-y}{x+y}$$
$$x^2+y^2 \le \frac{x-y}{x+y}+xy \le \frac{x-y+xy(x+y)}{x+y} \le \frac{x-y+2y}{x+y} \le 1$$. (Q.E.D.)
11K
