MHB [ASK] Integral - Draining a Pipe
  • Thread starter Thread starter bleedpurple
    Integral Pipe
bleedpurple
My first post, and first use of Latex. Here goes.
The engineering problem of calculating the time to drain a pipeline, tank, or vessel through an orifice is fairly straightforward using the orifice equation.\(Q=CA_{o}\sqrt{2gh}\)
With C being the coefficient of discharge for the orifice, Ao being the area of the orifice, g is the acceleration of gravity, and h the energy 'head' or elevation of the fluid above the orifice all in feet.
This equation can then be integrated by expressing Q as the change in volume over time.
\(Q=\frac{dv}{dt}\)
And expressing V as a function of head, h.
For a pipeline with constant gradient or slope the volume equals the cross sectional area of the pipe, Ap x length, and the length is the elevation change or head, h divided by the slope.
Therefore:
\(\frac{dv}{dt}=\frac{A_{p}}{slope} \frac{d_h}{dt} =C\,A_{o}\sqrt{2gh}\)and
\(\int{h^{-1/2}}dh=C\,A_{o}\sqrt{2gh} \frac{slope}{A_{p}} \int{dt}\)
or
\(\int{dt} = \frac{A_{p}}{slope} \frac{1}{CA_{o}\sqrt{2g}}\int{h^{-1/2}}dh\)
from this the result is
\(t=\frac{2 A_{p}}{slope} \frac{1}{CA_{o}\sqrt{2g}}(h_{1}^{1/2}-h_{0}^{1/2})\)
Now the case where there is also a constant flow in addition to the orifice flow.
\(Q=CA_{o}\sqrt{2gh}+K\)
resolves to the integral
\(\int{dt} = \frac{A_{p}}{slope CA_{o}\sqrt{2g}} \int\frac{1}{h^{1/2}+\frac{K}{CA_{o}\sqrt{2g}}}dh\)
from this the result is ?
Hi bleedpurple, welcome to MHB! (Wave)
Good job with the $\LaTeX$!
I take it you're wondering how to evaluate $\int \frac{dh}{\sqrt h + B}$?
If so, let's substitute $u=\sqrt h + B\Rightarrow h=(u-B)^2 \Rightarrow dh=2(u-B)du$:
$$\int \frac{dh}{\sqrt h + B} = \int \frac{2(u-B)\,du}{u} = 2\int (1-\frac Bu)\,du
= 2(u-B\ln u) = 2\Big(\sqrt h + B - B\ln(\sqrt h + B)\Big)
