Monoxdifly
MHB
- 284
A water container whose volume is 400 liters has 3 vertical holes. The first hole is located at the height which shows 300 liters. The second hole is located at the height which shows 150 liters. The third hole is parallel to the bottom. If the water in the container is drained by opening the holes one by one from the top to the bottom (second hole isn't opened until the first hole can no longer drain the water, third hole also isn't opened until the first and second holes can no longer drain the water), and the water container is empty in 10 hours, what are the debit (speed of draining water) of each holes?
