B Asking about integral notation
  • B
  • Thread starter Thread starter songoku
    Integral Notation
The integral notation ##\int_{a}^{x} f(t) dt## is preferred because it avoids confusion by using a different variable, t, for integration limits. Writing it as ##\int_{a}^{x} f(x) dx## implies that the variable of integration is the same as the upper limit, which can lead to misunderstandings. The notation emphasizes that t is a dummy variable, distinct from x, which is crucial for clarity in calculus. Additionally, the expression ##F(x) = \int f(x) dx## is valid, but it should not be conflated with the definite integral that has specific limits. Proper notation is essential for accurate mathematical communication.
songoku
TL;DR Summary
Why writing $$\int_{a}^{x} f(x) dx$$ is not correct?
Why should it be ##\int_{a}^{x} f(t)dt## ?
Couldn't it be like this:
Let F(x) = ##\int f(x)dx## so ##\int_{a}^{x} f(x)dx## = F(x) - F(a)
Thanks
Mathematics news on Phys.org
songoku said:
Summary: Why writing $$\int_{a}^{x} f(x) dx$$ is not correct?
Thanks
The integral ##\displaystyle{\int_a^b f(t)\,dt}## is short for ##\displaystyle{\int_{t=a}^{t=b} f(t)\,dt}.## If you use the same letter (##b=t##) for two different meanings then you cause confusion.
Likes songoku, dextercioby, mcastillo356 and 1 other person
Thanks
Why is it not correct to write $$\sum_{k = 1}^k a_k$$
Likes topsquark and songoku
Thank you very much for the explanation fresh_42 and PeroK
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
