Aspect of tensor-index notation
  • Thread starter HJ Farnsworth
  • Tags
    Notation
In summary: HJ FarnsworthIn summary, there is a difference between the components of a tensor indexed by Latin letters, specifically between M^a_{\hspace{2mm}b} and M_b^{\hspace{2mm}a}. This indicates that M in the latter case is not the same matrix as in the former case. The transformation that changes the matrix with components M^a_{\hspace{2mm}b} to M_b^{\hspace{2mm}a} is called a musical isomorphism and is analogous to the transpose operation. This is because M_b^{\hspace{2mm}a} is the transpose of M^a_{\hspace{2mm}
HJ Farnsworth
128
Greetings,
There is an aspect of tensor-index notation that I want to know more about. For a simple example, let [itex]M[/itex] be a [itex]1[/itex]-[itex]1[/itex]-tensor (ie., a matrix), whose elements can be indexed by Latin letters.
What is the difference between the component [itex]M^a_{\hspace{2mm}b}[/itex] and the component [itex]M_b^{\hspace{2mm}a}[/itex]?
The fact that there is a difference between the two components must indicate that the [itex]M[/itex] in the latter case is not the same matrix as the [itex]M[/itex] in the former case. Otherwise, since in both cases [itex]M[/itex] is a rank-[itex]2[/itex] tensor with one contravariant component, indexed above by [itex]a[/itex], and one covariant component, indexed above by [itex]b[/itex], the component [itex]M^a_{\hspace{2mm}b}[/itex] and the component [itex]M_b^{\hspace{2mm}a}[/itex] are both referring to the same matrix element, namely, that in row [itex]a[/itex] and column [itex]b[/itex]. So, if in both cases [itex]M[/itex] is the same matrix, then they both refer to the same matrix element of the same matrix, and therefore must be the same.
So, if [itex]M^a_{\hspace{2mm}b}[/itex] refers to a component of the matrix [itex]M[/itex], then [itex]M_b^{\hspace{2mm}a}[/itex] must refer to a component in the same row and same column of a different matrix, which I will call [itex]M^\#[/itex], just as [itex]M_a^{\hspace{2mm}b}[/itex] doesn't refer to a component of [itex]M[/itex], but instead refers to a component of [itex]M^T[/itex].
Firstly, could someone please confirm that this is what is going on?
More importantly, is there a name for the transformation that changes the matrix with components [itex]M^a_{\hspace{2mm}b}[/itex] to that with components [itex]M_b^{\hspace{2mm}a}[/itex]? In other words, is there a name for what I used the symbol [itex]\#[/itex] for in the previous paragraph, analogous to the transpose operation [itex]T[/itex] at the end of the paragraph?
Moving beyond the simple case of a [itex]1[/itex]-[itex]1[/itex]-tensor, is there a general name for operations which take an [itex]m[/itex]-[itex]n[/itex]-tensor indexed by [itex]m+n[/itex] indices, and switches some of the indices horizontally only (ie., switches around the location of contravariant and covariant indices, but doesn't make any contravariant components covariant or vice versa)?
Finally, does anyone have a good interpretation of the difference between the matrices [itex]M[/itex] and [itex]M^\#[/itex], ie., an intuitive sense of what it mathematically means to switch the horizontal position of two indices of a matrix (and, more generally, for a tensor)? Perhaps a very simple example would be rotations - if [itex]M[/itex] represents a rotation about some axis (not necessarily in Euclidean space, if a different space is needed for the index switch to matter), what exactly does [itex]M^\#[/itex] represent?
Thanks very much for any help that you can give.
-HJ Farnsworth
Greetings HJ Farnsworth! :smile:
see WannabeNewton's post (#2) in https://www.physicsforums.com/showthread.php?t=695850
(i did a tag search o:))
it makes a difference when you contract
(essentially, it's the same as the difference between Mab and Mba)
Hi tiny-tim, thanks for the response!
That is definitely a simple way to look at why they are different entities - a nice way to think about it using [itex]0[/itex]-[itex]2[/itex]-tensors (or [itex]2[/itex]-[itex]0[/itex]-tensors), since its a lot easier to see how those tensor components become different if the tensor is not symmetrical, and so immediately makes it clear that the horizontal switch does, indeed, have to make a difference. So, thanks very much for the link!
Does anyone know of the answers to my other questions? I think what I am most curious about is what the operation that I called [itex]\#[/itex] in my previous post would be called (ie., is their a name for the matrix [itex]M^\#[/itex] in my previous post, analogous to how [itex]M^T[/itex] is called [itex]M[/itex]-transpose?
Thanks again.
-HJ Farnsworth
##M_{b}{}{}^{a}## is the transpose of ##M^{a}{}{}_{b}##; you're just swapping the indices which is exactly what the transpose is. ##M_{a}{}{}^{b}## is a different object which is given by ##M_{a}{}{}^{b} = g_{ac}g^{bd}M^{c}{}{}_{d}## so it's related to the original tensor ##M^{a}{}{}_{b}## by means of the index raising and lowering operations given by the metric tensor ##g_{ab}##; in other words the metric tensor and its inverse define an isomorphism between contravariant indices and covariant indices of a tensor. This is called a musical isomorphism: http://en.wikipedia.org/wiki/Musical_isomorphism
Thanks for replying, WannabeNewton, as well as for your post that I was referred to earlier in this thread!
That may be just the thing I'm looking for, I'll look it up and learn about it.
[itex]M_{b}{}{}^{a}[/itex] is the transpose of [itex]M^{a}{}{}_{b}[/itex]
This is a minor point, and could just come down to a notational difference, but wouldn't [itex]M^{b}{}{}_{a}[/itex], rather than [itex]M_{b}{}{}^{a}[/itex], be the transpose element for [itex]M^{a}{}{}_{b}[/itex]? This seems correct to me just because, if we write the matrix [itex]M[/itex] and a vector [itex]v[/itex] as
[itex]M=
\left( \begin{array}{ccc}
M^{1}{}{}_{1} & M^{1}{}{}_{2} \\
M^{2}{}{}_{1} & M^{2}{}{}_{2} \end{array} \right)[/itex] and [itex]v=
v^{1} \\
v^{2} \end{array} \right)[/itex],
then we have
[itex]Mv=
M^{1}{}{}_{1}v^{1}+M^{1}{}{}_{2}v^{2} \\
M^{2}{}{}_{1}v^{1}+M^{2}{}{}_{2}v^{2} \end{array} \right)
=M^{i}{}{}_{j}v^{j}[/itex],
ie., this convention for [itex]M[/itex] does give us the right result using ESC. Then, taking the transpose of [itex]M[/itex], we get
[itex]M^{T}=
M^{1}{}{}_{1} & M^{2}{}{}_{1} \\
M^{1}{}{}_{2} & M^{2}{}{}_{2} \end{array} \right)[/itex],
so that it seems like we write the transpose of [itex]M[/itex] as [itex]M^{a}{}{}_{b}\rightarrow M^{b}{}{}_{a}[/itex].
Thanks again, I appreciate the help!
Related to Aspect of tensor-index notation
1. What is tensor-index notation?
Tensor-index notation is a mathematical representation used to describe the components of a tensor. It is commonly used in physics and engineering to simplify the notation of complex tensor equations.
2. How is tensor-index notation different from regular notation?
Tensor-index notation uses subscripts and superscripts to represent the indices of each component of a tensor, while regular notation may use commas or parentheses to separate components.
3. What are the benefits of using tensor-index notation?
Tensor-index notation allows for a more concise and elegant representation of complex tensor equations. It also makes it easier to perform calculations and transformations on tensors.
4. Are there any limitations to using tensor-index notation?
One limitation of tensor-index notation is that it can become cumbersome and difficult to read for tensors with a large number of indices. Additionally, it may not be suitable for representing certain types of tensors, such as non-symmetric tensors.
5. How can I learn more about tensor-index notation?
There are many resources available for learning about tensor-index notation, including textbooks, online tutorials, and video lectures. It is also helpful to have a strong understanding of linear algebra and vector calculus before diving into tensor-index notation.
  • Linear and Abstract Algebra
  • Differential Geometry
