ydan87
- 25
Hello all,
I need to implement iterative (non-recursive) binary search in assembly. The array has 10 elements, starting from 0x10000100, in address 0x10000004 there's the element to search for, and the answer should be put in address 0x10000008
It should be for MIPS and I ran it in QTSpim
Here's my code:
Code:
# this program implements binary search
# the equivalent pseudo code is the following:
# first = 0
# last = size -1
# while (last - first > 1) {
# mid = (last-first)/2 + first
# if A[mid] == val
# break;
# if A[mid] > val
# last = mid;
# continue
# else
# first = mid;
# continue;
.data 0x10000000
size: .word 0x0000000a # array size
.data 0x10000004
search: .word 0x0000000d # search term
.data 0x10000008
result: .word 0xblackff # result = -1
.data 0x10000100
array: .word 0x00000001 # the array
.word 0x00000005
.word 0x00000007
.word 0x00000009
.word 0x0000000b
.word 0x0000000d
.word 0x00000010
.word 0x00004000
.word 0x00050000
.word 0x00700000
.text 0x0400000
program:
sw $t0, 0 # $t0 = 0, that's our "first" pointer
sw $t1, size # $t1 - size
addi $t1, $t1, -1 # $t1 = size - 1, our "last" pointer
j condition # goto condition
nop
condition:
sub $t2, $t1, $t0 # $t2 = last - first
bgt $t2, 1, while # if ($t2 > 1) goto while
nop
j exit # if not, goto exit
nop
while:
div $t3, $t2, 2 # $t3 = (last - first) / 2
add $t3, $t3, $t0 # $t3 = t3 + first
lw $t5, 0($t3) # $t5 = array($t3)
lw $t6, result # $t6 = result
beq $t6, $t5, found # if value found, goto found
nop
bgt $t5, $t6, isGreater # if array[$t3] > result, goto isGreater
nop
addi $t0, $t3, 0 # else, first = mid
j condition # check the condition and start over the loop
found:
sw $t3, result # result = $t3
j exit # goto exit
nop
isGreater:
addi $t1, $t3, 0 # else, last = mid
exit: sw $t4, 0($t6) # result = $t4
j end # jump to end
nop
end: j end # internal loop to end the program
I get those errors in the run:
> Exception occurred at PC=0x00400000
> Bad address in data/stack read: 0x00000000
> Exception occurred at PC=0x0040007c
Any ideas what could go wrong?
