jbrisby
- 5
I am trying to create a MATLAB program that propagates the solar system when given initial velocity and position. I have successfully implemented a Runge-Kutta 4th order integrator but would like to see the difference when moving to an adaptive time step method. I think my problem arises when it comes to choosing the optimum time step for the next iteration. When checking the error of the position and using that to calculate the next time step I get a dt that approaches 4.2431e-06 and causes the integration to take exceedingly long periods of time to finish. The difp and difv are matrices of the error for position and velocity. I assume that I'm going to take the minimum value of the position difference because it will require the smaller time step. Any help would be greatly appreciated. Also, if it would help I can elaborate or provide more information if needed.
A reference for the Dormand Prince method if needed: http://depa.fquim.unam.mx/amyd/archivero/DormandPrince_19856.pdf
In the following code my accel() function calculates acceleration using Newton's Law;
pos and vel are 11x3 matrices for the bodies of the solar system being calculated;
dt is the initial time step;
c is a matrix of coefficients for the integration method;
c = [0 0 0 0 0 0
1/5 0 0 0 0 0
3/40 9/40 0 0 0 0
44/45 -56/15 32/9 0 0 0
19372/6561 -25360/2187 64448/6561 -212/729 0 0
9017/3168 -355/33 -46732/5247 49/176 -5103/18656 0
35/384 500/1113 125/192 -2187/6784 11/84 0
5179/57600 7571/16695 393/640 -92097/339200 187/2100 1/40];
k1v = accel(pos)*dt;
k1p = vel*dt;
k2v = accel(pos+(k1p.*c(2,1))).*dt;
k2p = (vel+(k1v.*c(2,1))).*dt;
k3v = accel(pos+(k1v.*c(3,1)+k2v.*c(3,2))).*dt;
k3p = (vel+(k1p.*c(3,1)+k2p.*c(3,2))).*dt;
k4v = accel(pos+(k1v.*c(4,1)+k2v.*c(4,2)+k3v.*c(4,3))).*dt;
k4p = (vel+(k1p.*c(4,1)+k2p.*c(4,2)+k3p.*c(4,3))).*dt;
k5v = accel(pos+(k1v.*c(5,1)+k2v.*c(5,2)+k3v.*c(5,3)+k4v.*c(5,4))).*dt;
k5p = (vel+(k1p.*c(5,1)+k2p.*c(5,2)+k3p.*c(5,3)+k4p.*c(5,4))).*dt;
k6v = accel(pos+(k1v.*c(6,1)+k2v.*c(6,2)+k3v.*c(6,3)+k4v.*c(6,4)+k5v.*c(6,5))).*dt;
k6p = (vel+(k1p.*c(6,1)+k2p.*c(6,2)+k3p.*c(6,3)+k4p.*c(6,4)+k5p.*c(6,5))).*dt;
k7v = accel(pos+(k1v.*c(7,1)+k3v.*c(7,2)+k4v.*c(7,3)+k5v.*c(7,4)+k6v.*c(7,5))).*dt;
k7p = (vel+(k1p.*c(7,1)+k3p.*c(7,2)+k4p.*c(7,3)+k5p.*c(7,4)+k6p.*c(7,5))).*dt;
k8v = accel(pos+(k1v.*c(8,1)+k3v.*c(8,2)+k4v.*c(8,3)+k5v.*c(8,4)+k6v.*c(8,5)+k7v.*c(8,6))).*dt;
k8p = (vel+(k1p.*c(8,1)+k3p.*c(8,2)+k4p.*c(8,3)+k5p.*c(8,4)+k6p.*c(8,5)+k7p.*c(8,6))).*dt;
difv = abs(k8v-k7v);
difp = abs(k8p-k7p);
s=(tol*dt./(2.*difp)).^.2;
dt = min(min(s.*dt))
