Assumptions in dark-energy density parameter measurement
In summary, the evidence for a non-zero ##\Omega_\Lambda## comes from supernova 1a measurements, where one measures the redshifts along with the luminosity distances (equivalently magnitude) of the supernovae and plots them against each other, then compares the result with theoretically derived curves for different values of cosmological parameters and find the parameter choices corresponding to the best fit. Combining this data with other data (such as the CMB) allows for a better understanding of the curvature of the universe.
center o bass
560
I've understood that the main evidence for a non-zero ##\Omega_\Lambda## comes from supernova 1a measurements where one measures the redshifts along with the luminosity distances (equivalently magnitude) of the supernovae and, plots them against each other, then compares the result with theoretically derived curves for different values of cosmological parameters and find the parameter choices corresponding to the best fit. (One example of such plots are shown here.)
From what I have read, the only two parameters that are being varied is ##\Omega_m## and ##\Omega_\Lambda## from which one gets the result approximately ##\Omega_\Lambda \approx 0.7## and ##\Omega_m \approx 0.3## supporting the claim that the universe is flat since ##\Omega_\Lambda + \Omega_m \approx 1##.
But here is the thing: since ##\Omega_k## was not varied, did we not already assume ##\Omega_k = 0## in the first place? Might it not have been the case that by also varying ##\Omega_k## this could've lead to a better fit with other parameter values than in the above result?
Or is there a good argument for why one can neglect ##\Omega_k## in the curve-fitting procedure?
Space news on Phys.org
As I understand it, it's because even if ##\Omega_k## isn't exactly zero, it's so close to zero (based on measurement that it can't significantly affect the analysis. The fact that the analysis ends up with ##\Omega_{\Lambda } + \Omega_m = 1## serves as a sanity check on the analysis; if that sum came out significantly different from 1, that would indicate a problem, since the analysis would be inconsistent with other measurements that indicate that the universe is extremely close to being spatially flat.
Supernova measurements, especially early ones, didn't actually constrain [itex]\Omega_k[/itex] very well. You could certainly let it vary, but the error bars on it are huge.
The way to resolve the discrepancy is to combine supernova data with other data, such as CMB data: the CMB constrains the curvature to be very close to flat. The basic picture here is that combining the CMB with nearby supernovae gives you a very long lever arm with which to measure curvature. To see why the long lever arm helps, consider the Earth: it's difficult to notice the curvature of the surface of the Earth while standing on the ground. But get far enough away, such as in low Earth orbit, and the curvature becomes quite apparent.
By the way, this is illustrated by this plot of the various errors of some of the different measurements:
http://www.astro.virginia.edu/class/whittle/astr553/Topic01/t1_cos_combined.gif
The clusters are nearly-vertical because measurements of galaxy clusters mostly provide an estimate of the matter density, but don't give much information about the cosmological constant. The CMB's errors run very close to the "Flat" line because the CMB mostly gives information about the geometry of the universe, but very little information about the total density. The supernova data runs at nearly right angles to the CMB data because the supernova data hardly constrains curvature at all, but does give a tight constraint to the ratio between matter and dark energy.
Thank you for your question. I would like to address your concerns about assumptions in the measurement of the dark energy density parameter.
Firstly, it is important to understand that the method used to measure the dark energy density parameter is based on the assumption that the universe is homogeneous and isotropic on large scales. This is known as the cosmological principle and is supported by observations such as the Cosmic Microwave Background radiation.
In addition, the assumption of a flat universe, where ##\Omega_k = 0##, is also supported by various observations, such as measurements of the cosmic microwave background and large-scale structure of the universe. Therefore, it is a reasonable assumption to make when measuring the dark energy density parameter.
Furthermore, while varying ##\Omega_k## may lead to slightly different best-fit values for ##\Omega_m## and ##\Omega_\Lambda##, the overall result of a flat universe with a non-zero dark energy density remains consistent. This is because the effects of varying ##\Omega_k## are relatively small compared to the effects of varying ##\Omega_m## and ##\Omega_\Lambda##.
It is also worth noting that the measurement of the dark energy density parameter is not solely based on supernova 1a measurements. Other observations, such as the large-scale structure of the universe and the cosmic microwave background, also support the existence of dark energy.
In conclusion, while it is important to consider all possible assumptions and sources of uncertainty in scientific measurements, the current evidence for a non-zero dark energy density parameter is supported by multiple observations and is consistent with our understanding of the universe as a whole.
Related to Assumptions in dark-energy density parameter measurement
1. What are assumptions in dark-energy density parameter measurement?
Assumptions in dark-energy density parameter measurement refer to the underlying beliefs or hypotheses that are made in order to estimate the value of this parameter. These assumptions can range from the behavior of the universe to the accuracy of the data being used.
2. Why are assumptions important in measuring the dark-energy density parameter?
Assumptions are important because they provide a framework for understanding and interpreting the data. They also allow for the development of models and theories that can be tested and refined over time.
3. What are some common assumptions made in measuring the dark-energy density parameter?
Some common assumptions include the homogeneity and isotropy of the universe, the validity of general relativity, and the existence of dark energy as a dominant component of the universe's energy density.
4. How do assumptions affect the accuracy of dark-energy density parameter measurements?
Assumptions can have a significant impact on the accuracy of measurements. If the assumptions are incorrect, the resulting measurements may be inaccurate or biased. Therefore, it is important to carefully evaluate and test the assumptions being made in order to improve the accuracy of the measurements.
5. What challenges are associated with making assumptions in dark-energy density parameter measurement?
One of the main challenges is that many of the assumptions being made have yet to be fully understood or proven. This can introduce uncertainty into the measurements and make it difficult to accurately estimate the dark-energy density parameter. Additionally, assumptions may also change over time as new data and theories emerge, which can further complicate the measurement process.
10K
  • Other Physics Topics
