Asteroid falling to earth, what will be minimum speed and KE on planet?
In summary: Just make sure your units are consistent. In summary, the gravitational pull of the Earth on an object is inversely proportional to the square of the distance of the object from the center of the earth. At the Earth's surface, this force is equal to the object's normal weight mg, where g = 9.8m/s^2. At large distances, the force is zero. Using the integral of work formula, the minimum speed of a 20,000-kg asteroid as it strikes the Earth's surface can be found by integrating the formula F = (mgR²)/r² from infinity to the surface of the Earth. This results in the asteroid imparting kinetic energy to the Earth upon impact.
overdrive7
The gravitational pull of the Earth on an object is inversely proportional to the square of the distance of the object from the center of the earth. At the Earth's surface this force is equal to the object's normal weight mg, where g = 9.8m/s^2, and at large distances, the force is zero. If a 20,000-kg asteroid falls to Earth from a very great distance away, what will be its minimum speed as it strikes the Earth's surface, and how much kinetic energy will it impart to our planet? You can ignore the effects of the Earth's atmosphere
K=(1/2)(mv2)
g=~1/r^2, where r is the distance from the center of Earth to the asteroid
W=∫Fxdx
I've seen a solution where the equation for potential energy (U) is involved, but it seems I'm supposed to solve this using calculus. I'm not quite sure where to start. I'm trying to use the integral of the work formula, but I'm not sure how to relate it to this problem where the gravity is involved. Thank you.
I'm glad to see you doing this, Overdrive. One should do it from basics until it gets boring, then use those more powerful formulas.
W=∫Fr*dr should do the trick. Your F will just be the big G formula for gravitational force. Show your work here if you want a check or help!
Thank you for the reply. By "big G formula", are you referring to the Gm1m2/r^2 formula? If so, is there a way to do it without the big G? I don't think I'm supposed to use the gravitational constant, because that is chapters away from where we are right now in our textbook (ch13 vs ch6).
Yes, that is the formula I meant.
Could this be suggesting you derive that formula?
F proportional to 1/r² means F = k/r²
At the surface of the Earth this is mg = k/R² where R is the radius of Earth, so k = mgR²
and so F = k*r² becomes F = (mgR²)/r²
(Hopefully this mgR² has the same value as G*m*M.)
It does neatly avoid using G.
Thank you! I will use that and find the integral from infinity to the surface of the earth, since it says "at large distances, the force is 0", so the infinity would cancel out and leave the KE when it hits the surface.. I hope that's correct.
Sounds good!
FAQ: Asteroid falling to earth, what will be minimum speed and KE on planet?
What is an asteroid?
An asteroid is a small rocky object that orbits the sun. They are typically irregularly shaped and can range in size from a few meters to hundreds of kilometers in diameter.
How fast do asteroids travel?
The speed of an asteroid can vary depending on its location in the solar system and its distance from the sun. On average, they can travel at speeds of up to 25 kilometers per second.
Can an asteroid fall to Earth?
Yes, it is possible for an asteroid to enter Earth's atmosphere and impact the planet's surface. However, most asteroids burn up in the atmosphere before reaching the ground.
What is the minimum speed an asteroid needs to have to reach Earth?
The minimum speed an asteroid needs to have to reach Earth is approximately 11 kilometers per second. This speed is known as the Earth's escape velocity, which is the speed needed to escape Earth's gravitational pull.
How much kinetic energy does an asteroid have when it impacts Earth?
The amount of kinetic energy an asteroid has when it impacts Earth can vary depending on its size and speed. On average, an asteroid can have several megatons of energy, which is equivalent to millions of tons of TNT.
