Asteroid on course with planet problem
In summary, the question is asking for the minimum energy required to split an asteroid of mass 5*10^20 kg and speed 10km/s into two equal pieces at a distance d from the moon's orbit, in order for each half to miss Earth by 600km. The attempt at a solution involved using conservation of angular momentum and energy equations, but the correct method may be to find the time to impact and use conservation of energy to determine the required horizontal velocity.
jj975
A asteroid of mass m=5*10^20 kg , speed u=10km/s is on a direct course to hit earth. If nuclear weapons are used to split it into two equal pieces at a distance away of the moon's orbit, d, what is the minimum energy required for each half to miss Earth by s=600km.
Conservation AM
Conservation of energy
Let the asteroid have initial horizontal speed v0 (from the blast) and speed v normal to the radial direction at its closest point to the earth
Let the Earth have radius R, mass M
Conservation of angular momentum: m(v0)d=mv(R+d)
Conservation of energy: m/2 (u^2+(v0)^2) - GMm/d = m/2 v^2-GMm/(R+s)
Solving these yields m/2*u^2 = (m/2*u^2+GMm/(R+s)-GMm/d)/(d^2/(R+s)^2-1) = Eblast
After substituting numbers this gives a ridiculously high energy. Does this look like a correct method? Thanks in advance
I assume you mean by "horizontal speed" you are talking about a speed in a direction perpendicular to u. Your last equation equates the blast energy to the total kinetic energy of the asteroid which doesn't sound right.
And I am not sure why you think angular momentum would apply here. The angular momentum of the earth-asteroid system before the nuclear explosion is zero since it is on a direct course. The explosion does give it an angular momentum but the question is what energy amount is required to cause this?
My guess is you simply have to find the time to impact and this will give you the required "horizontal" velocity and plug this into the conservation of energy equation:
total energy of asteroid before explosion = total energy of asteroid at point where s=600km
Related to Asteroid on course with planet problem
1. What is an asteroid on course with a planet problem?
An asteroid on course with a planet problem refers to a situation where an asteroid is heading towards a planet and could potentially cause significant damage upon impact.
2. How is the trajectory of an asteroid determined?
The trajectory of an asteroid is determined by measuring its position, velocity, and direction of travel. This can be done using telescopes, radar, and other space observation technology.
3. Can an asteroid be diverted from its course?
Yes, it is possible to divert an asteroid from its course through various methods such as using gravitational forces, spacecraft impact, or detonating explosives on or near the asteroid.
4. How much time do we have to prepare for an asteroid impact?
The amount of time we have to prepare for an asteroid impact depends on the size and distance of the asteroid. Smaller asteroids may only require a few days or weeks of preparation, while larger ones may require months or even years.
5. What are the potential consequences of an asteroid impact?
The consequences of an asteroid impact can vary depending on the size and location of impact. It could cause destruction of cities, tsunamis, and global climate change. However, the extent of damage can be mitigated through proper preparation and response efforts.
9K
