Astronomical cupolas & thermal equilibrium
In summary, astronomical observatories use white paint on their cupolas and building walls to reflect sunlight and minimize temperature differences between the interior and exterior at night. Aeration gaps may be present above the cupola to equalize temperatures, but they are not efficient during the day. Some observatories have green cupolas due to regulations or to blend in with the surrounding environment.
JeffOCA
49
Hi,
In astronomical observatories, the cupolas and their building walls are painted in white in order to reflect sunlight and not absorb too much warmth during the day. This minimizes the difference between internal and external difference when night falls.
However, in some observatories there are aeration gaps above the cupola. What for ?
If the cupola and its interior are heated by daylight, the gaps are useful to requilibrate the int. and ext. temperature at the beginng of the night.
But, during the day, these gaps are not efficient : warmed air from the outside enters the cupola where the air is colder.
Am I wrong ?
Other point : in some observatories the cupolas are green instead of white. Why ? Is it due to an oxydation of Cu ?
Thanks for answering.
JF
Astronomy news on Phys.org
No one ?
Anyone ?
It's not so much the temperature difference that kills you, but rather the air currents that get generated by the hot material.
Hot air rises so if you have a hole in the ceiling, the hot air won't come in.
Hmmmm... I did some googling, and found this paper on observatory construction...
http://tfa.cfht.hawaii.edu/papers/springer-tfa-paper.pdf
In section 2.1, they mention that they had to paint the dome green/gray because the Bureau of Land Management didn't want the observatory to spoil the view of the forest.
Thanks !
Related to Astronomical cupolas & thermal equilibrium
1. What is an astronomical cupola?
An astronomical cupola is a type of observation dome or turret found on top of a building, typically a observatory or astronomical laboratory. It is designed to provide a clear view of the sky for astronomical observations.
2. How does an astronomical cupola aid in thermal equilibrium?
An astronomical cupola aids in thermal equilibrium by allowing for proper ventilation and air flow. This helps to regulate the temperature inside the building and prevent it from becoming too hot or cold, which can affect the accuracy of astronomical measurements.
3. What materials are used to construct an astronomical cupola?
Astronomical cupolas are typically constructed using materials that are lightweight and have good insulating properties, such as metal, fiberglass, or glass. These materials also need to be able to withstand extreme weather conditions and maintain structural integrity.
4. How does the shape of an astronomical cupola affect its function?
The shape of an astronomical cupola can greatly affect its function. A dome-shaped cupola, for example, allows for a wider field of view and better air circulation compared to a flat or angled roof cupola. The shape also impacts the aesthetic design of the cupola.
5. Are there different types of astronomical cupolas?
Yes, there are various types of astronomical cupolas, each with their own unique design and function. Some examples include geodesic cupolas, onion-shaped cupolas, and hexagonal cupolas. The type of cupola used depends on the specific needs and requirements of the building and its intended use.
  • Earth Sciences
  • Earth Sciences
75K
