Asymmetry in Length contraction?
substitute materials
39
Instead of a twin paradox, let’s just consider an inbound starship approaching Earth at relativistic speed. The traveler is on a flyby mission, he will never change speed or direction. We will disagree with the traveler on how much time will have elapsed when he passes Earth. The discrepancy can be explained by length contraction, just as the asymmetry in the twin paradox is explained. He is closer to Earth in his reference frame than he is in ours. This is the physical meaning of the spacetime diagram.
But why do we see only the traveler’s ship as length-contracted, whereas the traveler sees the entire distance between us and him as length-contracted? Doesn’t this suggest a preferred reference frame for the Earthly observer?
  • Skeptical
Likes PeroK
We don’t, and no.
You are missing the important factor here: the relativity of simultaneity. In the situation you describe there is no one value for the distance. It is a function of time. If you pick a different time then you get a different distance. Because of the relativity of simultaneity you will pick different times and therefore get different distances. But it is entirely symmetric.
Likes FactChecker and Demystifier
You are talking about "the entire distance", but as @Dale points out relativity of simultaneity makes that a somewhat slippery concept.
We can try to make it more precise: imagine that we place a buoy in space, between earth and the spaceship and at rest relative to the earth. The "total distance" is the distance between where the earth is and where the buoy is, at the same time. Likewise, the length of the spaceship is the distance between where the nose is and where the tail is, at the same time.
We consider the problem from the point of view of the ship and the earth, at the exact moment that the nose of the spaceship passes the buoy.
Using the frame in which the ship is at rest, the buoy and the earth are moving so the distance between them is length-contracted; the ship is at rest so of course it is not length-contracted.
Using the frame in which the earth and the buoy are at rest, the distance between earth and buoy is not length-contracted but the ship is moving so is length-contracted.
Likes Gleb1964, DAH, PeterDonis and 1 other person
The asymmetry is in your problem statement, where you've chosen to regard "the entire distance between us and him" as something naturally measured in the rest frame of the Earth. In other words, you chose to prefer one frame's measure of distance which is why your explanation prefers one frame. This was an arbitrary choice since there is nothing actually marking the other end of "the distance", and it is this choice @Nugatory makes concrete by adding a buoy. You could have made the opposite choice, and then you would need to have added a buoy at rest with respect to the ship and your explanation would have been the other way round.
A symmetric scenario with well-defined notions of distance would be a pair of planets a light year apart in their rest frame and a pair of spaceships one light year apart in their rest frame and moving at 0.6c with respect to the planets. Both frames measure each object in the other frame cross the distance in 1.67 years, but with the moving objects' clocks showing 1.33 years elapsed. Both can explain that by saying the other frame measures the "entire distance" as only 0.8 light years. As @Dale points out, these symmetric explanations are available to both because, due to the relativity of simultaneity, the two frames are actually defining different lines in spacetime to be "the distance" between a pair of objects.
Likes PeterDonis
Any observer sees contracted all things that move relative to this observer.
The distance between two things is not a thing, so it is not seen contracted. The two things in this case move relative to each other, so the distance between them changes with time. The observer comoving with the first thing will see that the distance changes with time as ##L(t)##. The observer comoving with the second thing will see that the distance changes with time as ##L'(t')##. But there is a complete symmetry, because ##L## and ##L'## are really the same functions, in the sense that ##L(u)=L'(u)## for any real number ##u##.
No.
You need two events to define an elapsed time between them. You have specified only one event: traveler passes Earth. You need another event, otherwise the notion of an elapsed time is meaningless.
The other responses have given you examples of the other event, and shown you the consequences.
So the problem is synchronizing clocks to define the beginning of the travelers journey, yes? In Ibis' 2 planet example we can use the passing of the distant planet as the starting point, but we will disagree about when that happened, correct?
If we extend the buoy from Nugatory's response to become a rope stretched between the Earth and the traveler's initial location, at rest with respect to Earth, I understand that it would appear shorter to the traveler than to the Earth observer. I can make this work in my head. However if the rope was at rest with respect to the traveler, it should appear shorter to the Earthbound observer. But if that's the case, it's tantamount to saying the Earth bound observer sees the traveler as closer than the traveler sees them, which doesn't seem right. Will they disagree, using numbers from Ibix's example, by .33 years as to when the rope actually spanned the distance between them? Is this how simultaneity solves the problem? So I've turned the twin paradox into the ladder paradox.
Yes, that is correct.
I haven't checked the numbers to see if .33 is the right answer, but the principle is exactly as you say - because of relativity of simultaneity they find that the rope spanned the distance between them at different time, and of course the distance between them will be different at different time.
Yes, that's pretty much what you've done. The ladder paradox was invented to demonstrate the relativity of simultaneity, whereas the twin paradox avoids the simultaneity issue by comparing only colocated clocks.
(There is still a simultaneity issue in the twin paradox when we ask what number appears on the earth twin's wristwatch at the same time that the traveler turns around, when we can use any of three frames - eart at rest, traveler at rest during the outbound leg, traveler at rest during the inbound leg - to define "at the same time")
Likes vanhees71
FAQ: Asymmetry in Length contraction?
What is length contraction in the context of special relativity?
Length contraction is a phenomenon predicted by Einstein's theory of special relativity, where the length of an object moving at a significant fraction of the speed of light appears shorter along the direction of its motion, as observed from a stationary frame of reference.
Why does length contraction occur?
Length contraction occurs because, according to special relativity, the measurements of space and time are relative to the observer's frame of reference. When an object moves at high velocities, time dilates and lengths contract in such a way that the speed of light remains constant for all observers, preserving the principles of relativity.
How is length contraction asymmetrical?
Length contraction is considered asymmetrical because it depends on the relative motion between the observer and the moving object. An observer in the stationary frame sees the moving object's length as contracted, while an observer moving with the object sees no change in its length. This asymmetry arises from the relative nature of motion in special relativity.
Can length contraction be observed at everyday speeds?
No, length contraction is not observable at everyday speeds because the effects are only significant at velocities close to the speed of light. At everyday speeds, the contraction is so minuscule that it is practically undetectable.
How does length contraction affect measurements in different frames of reference?
In different frames of reference, observers will measure different lengths for the same moving object. An observer in the stationary frame will measure the moving object as shorter along the direction of motion, while an observer moving with the object will measure its proper length (the length in its own rest frame). This difference in measurements is a direct consequence of the principles of special relativity.
