Asymptotic Flatness: Minkowski Spacetime & Galaxy Scale
  • A
  • Thread starter Angelika10
In summary, in the derivation of the standard form of a spherical symmetric metric, it is always assumed that Minkowski spacetime is in the infinity. This is done for the purpose of physical viability and to ensure that spacetime is essentially flat far away from any sources or singularities. This assumption allows for the gravity of other objects in the galaxy to become negligible and for the metric to approach a flat form in the infinity. While there may be alternatives, such as assuming a vanishing spacetime in the infinity, these are highly speculative and not discussed in the scientific community. It is important to focus on learning and understanding the current models used in astronomy and cosmology, rather than speculating on alternative theories.
Angelika10
37
TL;DR Summary
In derivation of the standard form of a spherical symmetric metric, always the assumption is made: minkowski spacetime is in the infinity. Why is this done?
In derivation of the standard form of a spherical symmetric metric, always the assumption is made: minkowski spacetime is in the infinity. Why is this done? Could it be violated/not true? For example on the galaxy scale?
Angelika10 said:
Summary:: In derivation of the standard form of a spherical symmetric metric, always the assumption is made: minkowski spacetime is in the infinity. Why is this done?
It's a question of physical viability. What you're asking is why the gravitational effect of the Sun, for example, reduces with distance and eventually becomes negligible?
If it didn't, then the Earth would be significantly affected by the gravity of every star in the galaxy; plus every star in Andromeda.
There's no evidence for this. All the evidence points at the Sun having the only really significant effect.
In terms of asymptotic behaviour, the absolute mass is irrelevant.
Likes Angelika10
That is not entirely true. Even in the case of a spherically symmetric mass distribution in Newtonian gravity - you still have the option of an external field with zero divergence. This field is generally not considered to be part of the effect ”from the Sun”, but it does affect the boundary conditions.
The general idea however is that you want spacetime to be essentially Minkowski space far away from any sources or singularities.
Likes Angelika10
I fully agree for the asymptotical flatness of the solar system. It's measured with high precision.
But why do we assume the galaxy asymptotically flat?
Because flatness means "no influence of gravity" if we assume that gravity is the same as curvature of spacetime. I understand that.
But, in analogy to electrodynamics: There is "no field" the asymptotic, not "flat field", as in general relativity. Why can't we assume this? Something like "vanishing spacetime" in the infinity?
Yes, I see. But how do we know that it doesn't become "the opposite of minkowski" as it approaches infinity?
While deriving a metric from the standard form
##ds^2 = B(r)c^2dt^2 - A(r)dr^2 -r^2(d\theta^2 + sin^2\theta d\phi^2)##
It's always assumed that B(r) and A(r) approach to 1. I know that it's highly speculative, but could they divert from 1 in the infinity (B approching \infty, A approaching 0)?
This makes no sense.
Yes, which means it's out of bounds for PF discussion, since we do not allow discussion of personal speculations. Instead of spending time speculating, you should be spending your time learning how the models used in astronomy and cosmology actually work and why they make the assumptions they do.
Thread closed.
Likes Vanadium 50
FAQ: Asymptotic Flatness: Minkowski Spacetime & Galaxy Scale
What is asymptotic flatness in Minkowski spacetime?
Asymptotic flatness in Minkowski spacetime refers to the property of the spacetime being flat at infinity. This means that as you move further and further away from an object, the gravitational field becomes weaker and the spacetime approaches a flat, Euclidean geometry.
How does asymptotic flatness relate to the concept of gravitational potential?
The concept of asymptotic flatness is closely related to the gravitational potential of a system. In asymptotically flat spacetimes, the gravitational potential at infinity is zero, meaning that there is no net gravitational force acting on objects at infinity.
What is the significance of asymptotic flatness in Minkowski spacetime?
Asymptotic flatness is important in Minkowski spacetime because it allows us to define a well-behaved coordinate system at infinity. This makes it easier to study the behavior of objects and particles moving in the spacetime, as well as to calculate the effects of gravity on these objects.
How does asymptotic flatness play a role in galaxy scale structures?
In galaxy scale structures, asymptotic flatness is important because it allows us to model the gravitational potential of galaxies and galaxy clusters. This helps us understand the dynamics of these structures and how they evolve over time.
Can asymptotic flatness be observed in the real world?
Yes, asymptotic flatness has been observed in the real world through various experiments and observations, such as the bending of light near massive objects and the behavior of particles in the vicinity of black holes. It is also a fundamental assumption in many models and theories of gravity, such as general relativity.
