Asymptotic states in gauge theories
In summary: Also, he uses the by-now standard definitions* for physical states and operators in the covariant quantization of QCD.(*) See Ref’s [12], [13], [14] and [17] in Leader’s paper.
samalkhaiat
Insights Author
1,802
1,200
Moderator's note: This is a sub-thread spun off from https://www.physicsforums.com/threa...ergy-of-a-quantum-field-actually-zero.953766/.
vanhees71 said:
... this statement is indeed "modulo surface terms". Particularly I don't see any necessity for the energy-momentum tensor to be symmetric in the realm of special relativity.
I should have said that in certain cases in QFT, we can neglect “surface terms”. For example, the (on-shell) difference between the Belinfante and the canonical expressions for the angular momentum can be written as [tex]J^{ij}_{Bel} - J^{ij}_{C} = \int d^{3}x \ \partial_{\rho}F^{\rho 0 i j} (x) .[/tex] Now, by careful analysis using wave packets, one can show that the forward matrix elements of the RHS do vanish. Also, the forward momentum space matrix elements (i.e., the physical quantities in collision processes) of the “surface terms” do vanish if these terms are divergences of local operators.
But, you are absolutely right. As far as I know, the Belinfante expression [tex]J^{\mu\nu}_{Bel} = \int d^{3}x \left( x^{\mu} \theta^{0 \nu}(x) - x^{\nu} \theta^{0 \mu}(x) \right) , \ \ \ \ \theta^{\mu \nu} = \theta^{\nu \mu} \ ,[/tex] seems to fail to satisfy all the commutation relations of the Poincare’ algebra (to be more accurate, I should say that I have never been able to establish the correct bracket [itex]\big[i J^{0 j}_{Bel} , J^{0 k}_{Bel} \big][/itex] using the usual methods, and I don't know if somebody else had).
For gauge fields, of course you can argue with gauge invariance,
Again, one can show that the physical matrix elements of the generators are gauge invariant.
In my opinion, there's neither uniqueness in this split nor is there a really well defined treatment of spin in relativistic hydrodynamics,...
You are right on the "uniqueness" part. I had the pleasure of knowing and working with Elliot Leader on the very same problem (in QCD) for many years. So, I suggest you have a look at his book:
E. Leader, “Spin in Particle Physics”, Cambridge University Press (2001)
You may also find the attached PDF’s useful
  • Eilliot-1.pdf
  • Eilliot-2.pdf
  • Eilliot-3.pdf
  • Eilliot-4.pdf
Likes eloheim, Demystifier, dextercioby and 3 others
Thanks a lot! That's a lot food for thought :-)).
I once started to make the effort to show that the canonical-quantization approach without using the abstract construction of the representations of the proper orthochronous Lorentz group a la Wigner indeed leads to the correct local representations on the field operators when the Noether-charge definition of the conserved quantities are used. For free fields this works quite straight-forwardly. I'm not so sure about interacting fields though. I've written this up only in German:
https://th.physik.uni-frankfurt.de/~hees/faq-pdf/qft.pdf
It is not possible to find the exact form of interacting fields, simply because there is no exact solution to the field equations. However, the representation space of (interacting) field operators can be determined uniquely by the general principle of asymptotic completeness: [itex]\mathcal{V}_{in} = \mathcal{H} = \mathcal{V}_{out}[/itex]. So, you can apply the method, you described, to asymptotic fields, since any operator can be expanded into series of normal products of (free) asymptotic fields.
Likes bhobba and vanhees71
But this requires a free asymptotic field for each bound state, hence for QCD an inifinite number of fields.
See E. Leader paper in PDF #2 above, section V and VI and in particular the subsections VI.D & VI.E.
I don't think his exposition can be correct. Could you please explain how the claim in eq. (109) in Section VI.D that states in which quarks have definite momentum and gluons have definite transversal momentum are physical is consistent with confinement? ##m=0,n=1## would correspond to a physical single-quark state!??
There is no “physical single-quark state”. In his introduction, Leader tells you (throughout this paper “quark” will mean a sum over all flavours of quarks and antiquarks). Also, he uses the by-now standard definitions* for physical states and operators in the covariant quantization of QCD.
Kugo and Ojima define a physical state to be one annihilated by ##Q_B## and ##Q_C##. Leader claims on p.28 of arXiv:1101.5956v2 (your elliot-2) that ''the states with quarks having definite momentum ##P_1,\ldots,P_n## and transversal gluons having momenta ##k_1,\ldots,k_m## [...] are physical states''. Without any restriction on the number and momenta of the quarks. This is simply wrong.
This would not restrict the total number of quarks involved in any way. If such a sum were implied in his equation (109), it would be, as he explicitly stated, for definite momenta and hence for fixed (but arbitrary) ##n## and ##m##, including the 1-quark case ##n=1,m=0##. Maybe the paper is correct in spirit but it is certainly written so sloppily that essential assumptions are missing.
So does he. See equations (72) and (73).
Read the line just below equation (109).
This line just says that Leader's statement follows from commutation rules in the paper by Kugo and Ojima. But since Leader's statement is wrong, this implies that either this line itself or the paper by Kugo and Ojima is also faulty.
Indeed, looking at Kugo and Ojima, one finds that it is not about QCD at all but about SU(2) Higgs/Kibble (with broken symmetry) and pure Yang-Mills only. Hence they say nothing at all about quarks. This means that Leader's claim that his statement about QCD follows from Kugo and Ojima is wrong.
Moreover, Kugo and Ojima claim to have proved in paper III of their sequence (to which the cited paper refers for details about the pure Yang-Mills case) that the asymptotic gluon field is physical. But because of confinement it cannot be physical since it is colored! Thus their analysis is faulty, too. Indeed, they explicitly say that they ignore infrared effects - which make their asymptotic gluon field divergent, hence nonexistent.
Thus everything is based on faulty reasoning.
See also DarMM's comment here.
Likes dextercioby
All of Leader’s paper (given in the PDF’s) were published in Physical Review. The one in question was published 7 years ago
E. Leader, Phys. Rev., D83, 096012(2011)
So far, no one of the thousands of experts in QCD (around the world) has pointed out that Leader’s paper has any technical mistake. So, if you think otherwise, why don’t you write a letter to Phys. Rev. D. detailing any technical mistake in Leader’s paper? If you are unable to do so, then you should re-examine your (could be poor) understanding of QCD.
The physical content of (covariantly quantized) Yang-Mills theory and the confinement problem in QCD is the subject of chapter 4 in
N. Nakanishi and I. Ojima, “Covariant Operator Formalism of Gauge Theories and Quantum Gravity” World Scientific 1990.
So, have a good study of it, in particular the norm-cancellation mechanism (the so-called quartet mechanism).
Why do you argue from authority rather than by pointing out where my mistakes or misunderstandings are and why my arguments are not coherent (if they aren't)?
I published in Physical Review, too. I also know that there is no guarantee that results published there are correct. Thus what you write is not a logical argument against my statements.
According to the standards of mathematical physics, no one at present understands QCD, since currently there is not even a mathematically consistent definition of what QCD is.
This is a discussion forum, where things should be explained for everyone to check and understand at the indicated (in this case intermediate) level, rather than superficially settled by references to whole book chapters.
Likes vortextor and dextercioby
Me needs no authority in field theory, everyone in here knows this about me. You stamped Leader’s paper as “wrong” even before reading it. And talking about authority, Leader himself is an authority on QCD, with 45 years of expertise and impressive records of more than 200 published paper on the theory of strong interactions.
Asymptotic Completeness, Poincare’ covariance and the fact that (anti)commutation relations of asymptotic fields are c-numbers (Greenberg-Robinson theorem) allow one to determine all of the non-vanishing (anti)commutators of asymptotic fields in terms of the invariant functions [tex]D(x) = - \Delta (x ; m^{2})|_{m = 0} = - \frac{1}{2 \pi} \epsilon (x^{0}) \delta (x^{2}) ,[/tex][tex]E(x) = - \frac{\partial}{\partial m^{2}} \Delta (x ; m^{2})|_{m^{2} = 0} ,[/tex] and their spacetime derivatives. Now, by direct lengthy computations (using the properties of the invariant functions) you can show that [tex][Q_{B} , \vec{P}_{as}(q)] = [Q_{B} , \vec{P}_{as}(g)] = 0,[/tex] meaning that [itex]P^{i}_{as}(\mbox{quark})[/itex] and [itex]P^{i}_{as}(\mbox{gluon})[/itex] are observables with physical eigen-states in the sense that Fock states can be expanded in terms of these eigen-states in the process of evaluating the quarks and gluons contributions to the Nucleon momentum (see the paragraph after equation (103)).
Then you know that there are sections called “brief reports”, “rapid communications” and/or “letters to editors”. So, if you have found mistakes in Leader’s paper, then you may communicate your findings to Phys.Rev.D. Or, you could tell Leader directly (by Email) that his claim that [itex][Q_{B} , \vec{P}_{\mbox{as}}(q)] = [Q_{B} , \vec{P}_{\mbox{as}}(g)] = 0[/itex] is "not correct".
I did not say that “physical review paper" are necessarily correct. However, mistakes almost always (and here I am only talking about Phys.Rev.D and Phys.Lett.B) get discovered very fast. This is because: (i) usually there are thousands of people working on the same problem, and (ii) all serious researchers around the world read Phys.Rev.D and Phys.Lett.B.
Now, after 7 years in publications, nobody showed that Leader’s paper contains mistakes or said it is wrong. On the contrary, many people admitted to their mistakes that the paper said they did.
Actually, this is exactly the reason why I suggested a reference for you.
If I were to write about the physical content of the covariant QCD in here, my post would had been unreasonably long and complicated for “Forum discussions”.
The Hilbert space of nonperturbative QCD wouldn't be a Fock space though and the physical states couldn't be expanded in terms of quark-gluon states, as those states lie in a Hilbert-Krein space.
Wrong. The structure of the indefinite-metric Hilbert (Krein) space can be analysed as the Fock space of the asymptotic fields: By assumption [itex]Q_{B}|0 \rangle = Q_{c}|0 \rangle = 0[/itex], i.e., the charges of the BRST-algebra are not broken spontaneously. So, the classification of the representations of the BRST-algebra can be applied to the one-particle asymptotic states and translated into statements about the properties of creation and annihilation operators of asymptotic fields. See sections (4.1.2) & (4.1.3) of Nakanishi and Ojima book.
First the Hilbert Krein space is not a Fock space, which must be formed from Hilbert spaces, but that is a minor detail.
Secondly, I specfically said the physical Hilbert space, which is not a Fock space. The Hilbert space of any interacting theory beyond infrared cutoff ones in 2D are non-Fock.
I'm not talking about the Hilbert Krein space, as it contains non-physical states.
Kugo and Ojima's series of papers from the late-70s explicitly state that gluon and quark fields are non-physical.
For example Section VI of:
Taichiro Kugo, Izumi Ojima; Local Covariant Operator Formalism of Non-Abelian Gauge Theories and Quark Confinement Problem, Progress of Theoretical Physics Supplement, Volume 66, 1 February 1979, Pages 1–130
Likes dextercioby
But when claiming near (109) that the quark states are physical states Leader only discusses annihilation by ##Q_B##. What happens with ##Q_C##?
samalkhaiat said:
by direct lengthy computations (using the properties of the invariant functions) you can show that [tex][Q_{B} , \vec{P}_{as}(q)] = [Q_{B} , \vec{P}_{as}(g)] = 0,[/tex] meaning that [itex]P^{i}_{as}(\mbox{quark})[/itex] and [itex]P^{i}_{as}(\mbox{gluon})[/itex] are observables with physical eigen-states.
You claim that these observables are physical already because of commutation with ##Q_B## only. But this only proves (72), not (73). Thus your (and Leader's) arguments are incomplete and not conclusive. Maybe this is the cause of our disagreement?
Again you are making judgement before reading the relevant sections of the paper. In subsection A, after equation (73), Leader presents arguments for the fact that [itex]\vec{P}[/itex] has vanishing ghost number, and he does that for both the canonical as well as the Bellinfante expressions. You can also (if you wish) repeat the previous lengthy calculations replacing [itex]Q_{B}[/itex] by [itex]Q_{c}[/itex] to arrive at [itex][Q_{c} , \vec{P}_{as}] = 0[/itex] which is consistent with the following commutator of the BRST-algebra [itex][iQ_{c} , Q_{B}] = Q_{B}[/itex].
Again, I refer you to Nakanishi & Ojima book, section 4.1.3 "Multi-particle structure and asymptotic fields"
where the total state space [itex]\mathcal{V}[/itex] (i.e., Krein space) is analysed as the Fock space of the asymptotic fields.
AGAIN, I ask you to look up section (4.1.2) of the book, where (i) the cohomology group of the BRST charge [itex]Q_{B}[/itex] on [itex]\mathcal{V}[/itex]:
[tex]\mbox{H}(Q_{B}, \mathcal{V}) = \frac{\mbox{Z}(Q_{B} , \mathcal{V})}{\mbox{B}(Q_{B} , \mathcal{V})} = \frac{\mbox{ker}(Q_{B})}{\mbox{im}(Q_{B})} \equiv \frac{\mathcal{V}_{phy}}{Q_{B}\mathcal{V}} ,[/tex]
(ii) the representations of the BRST-algebra and (iii) the inner product structure, are studied in detail.
Statements like “gluon and quark fields are physical or non-physical” are meaningless and I don’t understand. What I do understand is the fact that the matrix elements of gluon and quark momentum and angular momentum are physically measurable quantities.
The 1990’s book of Nakanishi & Ojima is becoming the textbook study of the covariant operator formalism of gauge theories.
A local field is physical iff the corresponding smeared field operators map a dense subspace of the physical Hilbert space into itself.
I currently don't have access to this book, hence cannot use it within the present discussion.
I only judged that the visible argument was incomplete, which is correct. Now you completed it.
If your and Leader's statements are correct then there must be a clash in the terminology as used by Leader and you and the terminology used by mathematical physicists. I am familiar with the latter, so please provide a dictionary so that I am able to understand you.
1. For mathematical physicists, a Fock space is a Hilbert space with positive definite inner product, constructed as a tensor product of sy,mmetrized or antisymmetrized tensor products of 1-particle Hilbert spaces. Is this also your terminology? Or do you perhaps call analogous indefinite product spaces still Fock spaces?
2. For mathematical physicists, asymptotic fields are in 1-1 correspondence with points in the (real, nonnegative) discrete spectrum of the (self-adjoint, positive semidefinite) mass operator of the Poincare representation on the asymptotic state space, or with branch points of its spectrum (in case of theories without a mass gap). Is this also your terminology, or what is the corresponding relation in your terminology?
3. Assuming we agree on point 1 and 2, the asymptotic quark fields of QCD would have to carry a unitary representation of the Poincare group with nonnegative mass (and presumably spin 1/2). These masses would be well-defined parameters of QCD. What is the physical meaning of these masses? Is it current quark masses or constituent quark masses or something else? Or how is the Poincare group represented on the 1-particle Hilbert space corresponding to an asymptotic quark field?
4. Assuming we agree on points 1 and 2, and assuming in addition that QCD has a mass gap (which seems to me universal agreed upon), it should follow from Haag-Ruelle theory that the asymptotic fields satisfy the cluster decomposition principle and hence are not confined. Indeed, points in the discrete spectrum of the mass operator correspond to bound states, whose asymptotic fields satisfy cluster decomposition.
But bound states corresponding to single-quark fields are not observed. So some of your concepts must carry a different content from what I am used to from mathematical physics.
Please clarify!
A. Neumaier said:
Please clarify!
Sorry, I have been very busy lately. I will come back to you very soon.
where the total state space V\mathcal{V} (i.e., Krein space) is analysed as the Fock space of the asymptotic fields.
See @A. Neumaier 's point 1 above, Fock spaces have to have Hilbert spaces as their generator, not Krein spaces.
It's standard terminology in mathematical physics, see @A. Neumaier 's post.
No, that need not be the case in general. Fock space is the representation space of oscillators algebra, a complex vector space with non-degenerate inner product and unique vacuum annihilated by all annihilation operators. So, even in ordinary QM Fock space can have an indefinite metric. If fact, the quantization of any (oscillator) system with even number of first-class constraints leads to an indefinite metric Fock space. See the text
M. Henneaux & C. Teitelboim, "Quantization of Gauge Systems", (1992) Princeton Uni. Press.
where an infinite number of systems with indefinite-metric Fock spaces are given.
Krein spaces don't have an inner-product though right? They have a bilinear form that breaks one of the axioms for inner-products. Most Krein spaces have a subspace on which the restriction of this bilinear form gives an inner-product.
Wrong. They are assumed to have a non-degenerate indefinite inner-product. That is the defining axiom.
An inner product has to obey ##\langle x,x\rangle \geq 0## though right? Which the Krein bilinear form does not.
I repeat, Krein space is assumed to have non-degenerate, indefinite inner product: [itex]\langle \psi | \psi \rangle = \{ 0 , \ < 0 , \ > 0\}[/itex]
Okay fair enough, I never knew that was called an indefinite inner-product, I thought that was physicist's terminology only, but I see in the Krein case it isn't called a bilinear form in general, but due to the existence of the ##J## endomorphism (implying a Hilbert subspace) it is called an indefinite inner product space.
Still though, I don't see in a definition of a Fock space permitting a Krein space as the generator, most definitions I see require a Hilbert space.
Also related to the original point, the quark and gluon fields map out of the Hilbert-space into the Krein space, so they can't be observables.
Related to Asymptotic states in gauge theories
1. What are asymptotic states in gauge theories?
Asymptotic states in gauge theories refer to the states of a physical system that are observed at infinite distances from each other. In other words, these states are described by the behavior of the system at very large distances or times, where the effects of interactions become negligible.
2. How are asymptotic states related to gauge symmetries?
Gauge symmetries are mathematical transformations that do not change the physical state of a system. In gauge theories, the physical states of the system are described by the asymptotic states, which are invariant under gauge transformations. This is because the effects of interactions become negligible at infinite distances, making the gauge transformations irrelevant.
3. Can asymptotic states be observed in experiments?
While asymptotic states cannot be observed directly, their effects can be observed in experiments. For example, the scattering amplitudes of particles at very high energies can be calculated using the asymptotic states, and these predictions can be tested in experiments.
4. How do asymptotic states affect the renormalization of gauge theories?
Asymptotic states play an important role in the renormalization of gauge theories. In order for the theory to be well-defined, the asymptotic states must satisfy certain conditions, such as being free of infrared divergences. These conditions help to ensure that the theory is consistent and can make meaningful predictions.
5. Are asymptotic states unique in gauge theories?
No, asymptotic states are not unique in gauge theories. Different choices of asymptotic states can lead to different predictions for the same physical system. However, these different choices must still satisfy the necessary conditions for the theory to be well-defined, as mentioned in the previous question.
  • Quantum Physics
  • Quantum Physics
