Asymptotic states in the Heisenberg and Schrödinger pictures
UnreliableObserver
In scattering theory, the quantity of interest is the amplitude for the system—initially prepared as a collection of (approximate) momentum eigenstates—to evolve into some other collection of momentum eigenstates. For example, for scattering, the amplitude we're interested in is where is the time at which we prepare the state, is the time at which we observe the result of the scattering process, and is the time evolution operator.
We can imagine finding operators capable of creating such states from the vacuum, in which case we could write as or, in the Heisenberg picture, where . I hope this is all rather uncontroversial so far.
Now, it can be shown (see e.g. Srednicki QFT) that the operators that create single-particle momentum eigenstates from the vacuum are where
However after this point things start to fall apart for me. According to everything I've read, these operators are used to create the "initial" and "final" states and , with which the corresponding S-matrix element is given as . But how can this be right? If these operators do indeed create single-particle momentum eigenstates, then isn't this inner product very trivial? If we refer back to the Heisenberg picture expression , we are free to write it as , but these states are clearly not products of momentum eigenstates, but rather whatever complicated mess results from the action of on the vacuum (as they must be to give a non-trivial amplitude). The products of eigenstates are those in , so shouldn't the operators instead assume the role of those in ?
First of all it should be
Then using you can see that indeed (2) and (3) are equivalent. Also note that the products are not trivial, because the annihilation operators, creating the final states out of the vacuum, are at time and the creation operators, creating the initial states out of the vacuum, are at time .
It's indeed everything else than trivial to understand this subtle point of asymptotically free in and out states. Everything boils finally down to the socalled "LSZ-reduction formula" (named after Lehmann, Symanzik, and Zimmermann).
I think this point is best explained in the good old book by Bjorken and Drell, Quantum Field Theory (not the other one, named "relativistic quantum mechanics", which discusses a completely outdated version called "hole theory" a la Dirac; QFT is at the end more consistent and easier to understand).
Likes dextercioby, PeroK and topsquark
Thanks for the reply vanhees.
I don't think this is true. Using , can be written as which recovers .
However, this isn't the part I'm concerned about.
Let me clarify. I'm perfectly happy with the progression from -. That is, I accept that and are equivalent and are both non-trivial expressions. The issue I'm having is with reconciling them with how the asymptotic operators are used in the literature. Here's the breakdown:
  1. In , the vectors are momentum eigenstates (by construction). The product of momentum eigenstates is evolved forward in time to and compared with . This inner product is clearly non-trivial.
  2. In , the vectors are not momentum eigenstates, but in general some complicated states with a form that depends on the interactions. The inner product between and is clearly non-trivial and is equal to .
  3. The asymptotic operators are the operators that create momentum eigenstates from the vacuum. That is, is a momentum eigenstate. The inner product between and therefore is trivial. The operators act like those in but are used like those in ! What gives?
As I said, it's not that simple. Look up the LSZ reduction formalism. As I said, it's most clearly explained in the QFT book by Bjorken and Drell.
UnreliableObserver said:
... but these states are clearly not products of momentum eigenstates, but rather whatever complicated mess results ...
You should distinguish the final state before measurement, from the final state after the measurement. The final state before measurement is indeed a mess, as you said. This mess can be written as a messy superposition of momentum eigenstates, because the momentum eigenstates constitute a (Fock) basis. But when we measure, what we observe is a definite number of particles with some definite momenta. In other words, we measure in the Fock basis of momentum eigenstates, so the state after the measurement is one of those Fock states. Hence the state after the measurement is no longer a mess at all. But we do not know in advance which particular non-messy state will this be, so we compute the probability of ending up in any particular non-messy state. The S-matrix element is precisely the probability amplitude that the messy state before measurement will end up in a certain non-messy state after the measurement.
With equations, the final state before measurement is , which is a mess when written explicitly. Denoting the final state after the measurement with , the probability amplitude that the final state after the measurement will be is
A note on notation: Sometimes people denote with or something like that, write the probability amplitude above as , and then further shorten the notation by writing it just as . Such a shorter notation is rather confusing and misleading.
Likes PeroK
Hi Demystifier. I agree with everything you've said, however the states and you refer to are the states and I wrote down in the Schrodinger-picture expression . These are different to the "messy" Heisenberg picture states, and , that I refer to in the final paragraph. My confusion concerns the fact that the asymptotic operators are said to create momentum eigenstates, which would make the inner product between and simply an inner product between collections of momentum eigenstates, which is very trivial (a delta function). Yet, in every QFT text I've come across, this inner product is said to be the relevant -matrix element.
vanhees has suggested things are more subtle than this, so I will give Bjorken and Drell a read. From skimming -matrix chapter, it seems that I might be failing to distinguish between the states created by (the "in" states) and those created by (the "out" states). Even though the inner product between a pair of "in" states or a pair of "out" states is trivial in the sense I described, the inner product between an "in" state and and "out" state is (somehow) the non-trivial -matrix element.
I'll report back 🙂
Likes vanhees71, Demystifier and PeroK
The point is that do not create single-particle momentum eigenstates. Only do, and .
But and satisfy the same creation and destruction algebra, as and . So what do create? In the condensed matter language, I would say that they create "quasi-particles", rather than physical particles. What exactly is the difference? The world of these "quasi-particles" alone looks the same as the world of "physical particles" alone. What distinguishes them is their properties relative to our measuring apparatuses. Our measuring apparatuses are made such that only states created by manifest as particles in the way we are used to. In principle one could construct a different measuring apparatus with which only states created by manifest as particles in the way we are used to, but in practice we don't work with such measuring apparatuses. An example of a "different measuring apparatus" that sees "quasi-particles" as particles we are used to is an accelerating particle detector, this effect is known as Unruh effect.
and
In view of my post above, the first formula is correct but the second isn't. Perhaps the second formula could be written more correctly as
where the bar denotes that these states are "quasi-particles", rather than physical particles.
Finally getting back around to this :)
So it seems that was indeed it. The problem was that I was writing down all these momentum eigenstates without paying attention to which momentum operators they are actually eigenstates of!
The operators don't just "create momentum eigenstates", they specifically create eigenstates of the asymptotic momentum operators . Likewise, the create eigenstates of the Schrödinger-picture operator . My problem was implicitly thinking of and as collections of eigenstates of the same Schrödinger-picture operator , when they are really eigenstates of two different operators ( and ), making their inner product very non-trivial indeed.
This also makes it clear how the fixed Heisenberg picture states and can be interpreted as particles at asymptotic times. It is obvious in the Schrödinger picture, where one explicitly evolves the state—initially in a product of eigenstates of the (fixed) operator at —to . In the Heisenberg picture, it is the operators that undergo the evolution, and the (fixed) state is a product of eigenstates of the momentum operator only at the specific times . So the pictures are equivalent.
It seems quite simple in hindsight. Neverthless, do let me know whether or not this all makes sense!
Likes vanhees71
